Thread: Mk3 97 GTI Rear Shock Problem
  1. Exclamation Mk3 97 GTI Rear Shock Problem
    Aug 2009
    Wanborough UK
    Hi All
    Just joined the forum today as i have just brought myself a 97 GTI in very nice condition.
    BUT when i put it in for MOT last week it failed on rear shock absorbers. I went online an brought a new pair which arrived yesterday. So ok i got the first one off this morning fairly easy but the new unit does not have the bottom spring holder/collar only having raised stops around it indicating that the holder/collar should be removed from the old unit and fitted to the new one as an interference fit.
    Having looked at the original unit it doesnt look like this spring holder/collar actually comes off!!
    Can any of you good forum members give me the benifit of your knowledge on this subject, is it just that the old unit is so crusty it looks like the collar cant be removed even though i have soaked it etc or have i brought the wrong replacements even though they listed for my model.
    Look forward to your advice and help.
  2. Re: Mk3 97 GTI Rear Shock Problem
    Jan 2009
    towcester northants
    bottom collars usually come seperate
    if its had non gen rear shocks before then they may not be a seperate item
    you can buy them seperatly
  3. Re: Mk3 97 GTI Rear Shock Problem
    Aug 2009
    Wanborough UK
    Hi, thanks for that info I will check it out and find out how much and where to get them.
  4. Re: Mk3 97 GTI Rear Shock Problem
    May 2008
    Send the shocks back they should come with the lower plate mounts by default.
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. Mk5 GTI DSG Gearbox noise problem
    By kerimpal in forum Chat - Anything with wheels
    Last Post: 13-05-2008, 09:22 PM
  3. Golf Mk3 TDI Rear Suspension Knock problem?????
    By broomeyMk3TDI in forum Golf MK3 - 1993 - 1999
    Last Post: 01-10-2007, 11:28 PM
  4. Volkswagen Golf Gti W12 Set To Make Uk Debut
    Last Post: 09-06-2007, 04:44 PM
  5. Volkswagen Unveils Golf Gti W12-650 Design Study
    Last Post: 22-05-2007, 08:24 PM
