Thread: air-con temp
  1. air-con temp
    Feb 2007
    Flint, N.Wales
    Can anyone tell me why my climatronic is only displaying the outside ambient temperature no matter what temp is, inside car, heaters and cooling seem to work fine, cheers.
    7 Post(s)
    That what is does.
    It doesn't display the internal temp if that is what you mean?
    Feb 2007
    Flint, N.Wales
    Quote Originally Posted by BigCol View Post
    That what is does.
    Sory Col, I think your talking about the temperature display on the dash. I mean the indicated temp on climatronic display, one shows what temp you have set aircon to regulate and another smaller one I think its on the left should show actual temp inside car, it has worked before but is only showing outside temp now asthis always matches dash temp display at present. I did enquire at main dealer but blonde girl on service desk said it means aircon needs re-gassing!
    Oct 2005
    Lutterworth
    Quote Originally Posted by chisel View Post
    The left temp is the outside air temp and matches the dash display, minus the 0.5, and the right temp is what you have set the climate to.
    As far as I know there is no provision to display the actual interior temp without using the diagnostic mode.
    The fan speed tells you how close the actual interior temp is to that you have set. :-)
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Tyldesley, Manchester, UK
    I concur with Lex Luthor and BigCol. Mine has never displayed the temp inside the car.
    Feb 2007
    Newcastle upon tyne
    Mine neither!
  1. A3 Temp gage
    By Graham in forum Audi A3 - Archive Topics
    Last Post: 07-04-2007, 03:09 PM
  2. temp gauge
    By garying3980 in forum Passat - Archive Topics
    Last Post: 11-02-2007, 03:06 PM
  3. where's the temp sensor?
    By megoodsen in forum Passat - Archive Topics
    Last Post: 21-12-2006, 09:53 PM
  4. 150 tdi temp sensor
    By bazzle in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-12-2006, 10:08 PM
  5. TEMP GAUGE
    By GARY in forum Passat - Archive Topics
    Last Post: 30-11-2006, 05:14 PM
