Thread: Brake warning light on startup
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. Re: Brake warning light on startup
    #21
    May 2007
    knee deep in clunge
    14 Post(s)
    The correct battery is a must.You say beeps but do you see a brake warning signal on the driver display.
  2. Re: Brake warning light on startup
    #22
    Nov 2008
    Yes, Brake warning in red keeps flashing and beeps 3 times. All the same as before.
    Looks like the new battery has a lesser startup power.
    many thanks
  3. Re: Brake warning light on startup
    #23
    Nov 2008
    Still having a nightmare with this. As it stands -
    Old battery (original) - 12V 340A 70AH (570A CCA)
    1st new battery - 065 66AH (495 CCA) - still getting beeps mulitple times on startup
    2nd new battery - 067 66AH (580 CCA) - still the same.
    Does anyone know if this second new battery is acceptable for the car. Startup power (CCA) is higher than my original but the capacity (AH) is slightly lower.
    Just want to know should I return both and get my money back and look elsewhere for the exact one. Halfords list four batteries for my car some are more powerful than all of the above and others are less powerful.
    http://www.halfords.ie/webapp/wcs/st...dPartsMMYS.y=8
  4. Re: Brake warning light on startup
    #24
    Nov 2008
    Went back to the garage for a larger battery and the mechanic said that there would be no point in anything bigger as the second one he gave me is more than powerful enough adding that its mostly for diesels.
    I notice the beeps are becoming more frequent but still stop after about 10mins of driving.
    Is there anyway to just turn off the beeping sound?
  5. Re: Brake warning light on startup
    #25
    Aug 2015
    Bristol
    Does anyone have the link on info for the relay mod? Cheers Dave.
  6. Re: Brake warning light on startup
    #26
    1840 Post(s)
    Remind me tomorrow and I will dig it out but Photoknobit will probably stop me posting it even though I pay, right bunch of knobs!
  7. Re: Brake warning light on startup
    #27
    Aug 2015
    Bristol
    Nice one, thanks. If it's easier I could give you my email address?
    Dave.
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
  3. Brake Pad Warning Light 54 Reg Passat Estate
    By alflavor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-04-2007, 02:52 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
