Thread: Temperature gauge reading lower than actual temperature
Results 1 to 9 of 9
  1. Temperature gauge reading lower than actual temperature
    Bit of an odd one - I noticed a few months ago that my temperature gauge is showing a rather low temperature when the car is obviously running hotter. At normal engine temp the gauge is showing 70degrees. When I check the temp sensor reading via VAG-COM it is showing 90 degrees. Surely a temperature gauge does not just drop 20 degrees?
    Any ideas?
    Golf GTi 16v ABF Engine
    138K miles
    1994 plate
  2. Re: Temperature gauge reading lower than actual temperature
    Aug 2009
    Wolverhampton England
    Yeh my wife's car does exactly the same - any ideas anyone please.
  3. Re: Temperature gauge reading lower than actual temperature
    Southern County Softy
    20 Post(s)
    Coolant temp. sensor fault.
    A4 2.5 tdi QS (mapped)
  4. Re: Temperature gauge reading lower than actual temperature
    But the VAG-COM is showing a correct temperature reading so surely the sensor must be OK?
  5. Re: Temperature gauge reading lower than actual temperature
    20 Post(s)
    The sensor sends 2 signals, 1 to the ECU, which you are seeing with vagcom, the other goes to the gauge on the dash, which is reading low. half of the sensor has failed.
  6. Re: Temperature gauge reading lower than actual temperature
    OK, thanks, i'll give it a try
  7. Re: Temperature gauge reading lower than actual temperature
    Jan 2009
    towcester northants
    gary you can check temp sensor reading through engine measuring blocks and also dash pod measuring blocks to confirm if sensor or dash fault
  8. Re: Temperature gauge reading lower than actual temperature
    towstervag, please can you explain in more detail what you mean? What are engine measuring blocks and dash pod measuring blocks and what do I need to to perform the test? Thanks in advance.
    Gary
  9. Re: Temperature gauge reading lower than actual temperature
    Jan 2009
    towcester northants
    measuring blocks are the readings given to the ecus ie coolant temp sensor gives reading to engine ecu on one side of the sensor so coolant temp can be 0-100 degrees etc its for correct fueling and you can read this figure through vag com
    the other side of the temp sensor give your temp guage its reading through your dash
    as you probably know 01 is engine and you can read the signals/ data ie engine temp
    17 is dash pod and you can do the same and read engine temp
    so you can compair the readings to confirm your fault
  1. V6 Syncro problems !!
    By syncromonkey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 05:58 PM
  2. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
  3. Climatronic Diagnostics
    By milenia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2007, 10:17 AM
  4. A4 Temperature Gauge not reading
    By GT001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2007, 04:11 PM
  5. vag com codes
    By marty67 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2007, 09:12 PM
