Thread: Possible ecu problem ???
  1. Possible ecu problem ???
    Aug 2009
    Norwich
    Hi newbie here
    I've just brought a 98 passat 1.8 20v turbo with a tiptronic box.
    the problem i've got is that the car seems to be in limp home mode whilst trying to go through the gears. I've also got NO lights on the dash so have no idea what gear i'm in
    could this all be related to the ecu in the front footwell ??
    I've now got 3 days off to try and sort this
    Many thanks for any help
    Kevan
  2. Re: Possible ecu problem ???
    Jan 2009
    towcester northants
    get diag test done it could be just a multi function switch
    check for water in drivers footwell
  3. Re: Possible ecu problem ???
    Aug 2009
    Norwich
    Thanks for the reply.
    Finally got round to looking at it today and after checking the multi plug and CCM in the footwell - both fine with no corrosion or wet carpets !! - going to local specialist for diagnostic tomorrow. Will also get them to do the gearbox fluid whilst there as it cannot hurt.
    Hopefully all will be fixed for little money
    Will keep updated as it's a shame to scrap it, especially bearing mind it has full service history and only done 100,000 miles
  4. Re: Possible ecu problem ???
    Aug 2009
    Norwich
    Just found out the wiring is caput, so much so that couldn't even get a full diagnostic from it!!
    Ah well back to the auction she goes
  1. Problem with VAG DSG Gearbox?
    By stuart in forum Chat - Anything with wheels
    Last Post: 21-01-2010, 12:51 AM
  2. Please Help 1.8 BFB engine problem
    By madein in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-04-2009, 03:22 PM
  3. overheating problem 98 1.8 20v
    By victhepick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2008, 10:39 AM
  4. Power problem turbo not working
    By marfitzd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2008, 11:04 AM
  5. Auto/tiptronic gearbox ecu problem
    By jewelldo in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 09:57 PM
