Thread: alarm fault codes
  1. alarm fault codes
    Feb 2009
    NEWPORT
    hi last week i adjusted the codes on my a4 b6 coz i wanted to hear the beep when i locked the car, i tried a few other things too like auto locking the doors when the car drives off etc. just ran vag com on the car and its thrown up some fault codes.
    these were my fault codes before i adjusted anything.
    Address 45 -------------------------------------------------------
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0503
    Coding: 00001
    Shop #: WSC 00000
    No fault code found.
    Address 46 -------------------------------------------------------
    Controller: 8E0 959 433 AJ
    Component: Komfortgerát T9F 0619
    Coding: 06859
    Shop #: WSC 00613
    2 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01331 - Door Control Module: Driver Side (J386)
    53-10 - Supply Voltage Too Low - Intermittent
    i was cool with these because i knew when i ran vag com i had the door open window open etc so it would flag up a few codes but since i adjusted module 46 Comfort System
    i have these fault codes
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Coding: 07403
    Shop #: WSC 00613
    4 Faults Found:
    01616 - Signal Wire to Interior Monitor
    49-10 - No Communications - Intermittent
    35-00 - -
    01403 - Glass-Break Sensors: Rear
    36-10 - Open Circuit - Intermittent
    53-00 - Supply Voltage Too Low
    if any one could help me id be greatful thank you
  2. Re: alarm fault codes
    First i would say there is a bad connection to the drivers side, door modul,and can you explain how you arrived at the code 07403,which functions you coded for
  3. Re: alarm fault codes
    Feb 2009
    NEWPORT
    i have no idea kenney
    i just clicked on auto scan and that all comes up. its all sorted now i cleared the codes and they never came back. so i guess thats all that it needed. turned the alarm on left it for a while came back and rechecked the scan and still no faults, i just left the usb cable in the door and shut it so now i get no fault codes what so ever, well except the radio ue to installing an after market one. thank you ne wayz kenney
  1. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
  2. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  5. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
