Thread: '97 cabriolet brake warning light
Results 1 to 10 of 17
  1. '97 cabriolet brake warning light
    my 1800cc cabriolet has developed an annoying warning light feature. i have had the car checked and there appears to be no fault with the brakes pads discs fluids. however the brake warning light is a constant feature. any ideas as to how and where i might start to solve this. cheers john
  2. Re: '97 cabriolet brake warning light
    to eliminate the reservoir sensor,remove the contact and bridge the terminals
  3. Re: '97 cabriolet brake warning light
    i tried that and when the plug was bridged the light on the dash remained on constantly
    does it work on a making or breaking of the circuit?
    thanks for your reply
    regards
    john
  4. Re: '97 cabriolet brake warning light
    Making.When you say constant feature,does that mean the light is on all the time?
  5. Re: '97 cabriolet brake warning light
    when i am driving along it gives the warning beeps then flashes. after a short while it beeps again and keeps flashing. i dont understand if it makes how bridging the terminal of the power to the fluid would help. cheers john
  6. Re: '97 cabriolet brake warning light
    The resorvoir switch,indicates when the fluid is low,they can sometimes,be faulty.The suggestion was to eliminate it.Do you know if you have break wear inicators on both of the front calipers.One other thing if you bridge the connector,with the ignition on,the control light will light constant.
  7. Re: '97 cabriolet brake warning light
    you're a star. i'll have a look at it tomorrow, many thanks for your interest
    regards
    john
  8. Re: '97 cabriolet brake warning light
    i bridged the terminals from the reservoir plug and started the engine. immediate response from warning light. then i removed a front wheel and found the wires are attached to the front of the brake so i have no way of knowing whether they go through to the calipers on the back. so cant tell you if both inner and outer caliper is wired up sorry regards john
  9. Re: '97 cabriolet brake warning light
    I know there is only the one pad with the brake pad warning,i meant both front wheels
  10. Re: '97 cabriolet brake warning light
    ok. sorry. i removed the nearside one, tomorrow i will take off the other and check for similarities/differences. thanks for your time regards john
  1. Polo brake light switch
    By mark smith1951 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-01-2008, 05:55 PM
  2. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  3. Brake Pad Warning Light 54 Reg Passat Estate
    By alflavor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-04-2007, 02:52 PM
  4. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
