Thread: Audi a6 Airbag Light P plate
  1. Audi a6 Airbag Light P plate
    May 2009
    Leicestershire
    Hi
    I wonder if anybody has any suggestions on a little problem i have with my airbag light?
    Whilst on holiday i blew the fuse for the cigarette lighter but as I didn't have any books with me i proceeded to pull each fuse to find the blown one ( turned out in the end it was one of only two under the bonnet grrr).
    Anyway since doing this my airbag light remains on for around 5 mins when the key is turned, it dosent matter whether the engine is started or just left with the key turned the light will stay on for around 5 min's then go off ???
    Anybody have any ideas on what could be causing this ??
    Many thanks for looking
  2. Re: Audi a6 Airbag Light P plate
    May 2007
    sounds like a fault code locked in the ecu. If you have access to vag-com you can probably reset it, if not a lot of faults reset after so many starts without it happening, so it may appear to go away.
  3. Re: Audi a6 Airbag Light P plate
    May 2009
    Leicestershire
    Ok cheers m8 fingers crossed then
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  3. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  4. At home on all roads and tracks - Audi A6 allroad quattro
  5. Audi launches a major broadcasting revolution
    Last Post: 31-10-2005, 09:01 PM
