Thread: A6 2.5tdi sport fault code pls help
  1. Exclamation A6 2.5tdi sport fault code pls help
    Jul 2009
    kent
    hi guys! can someone tell me what these fault codes mean.
    18226 (p1818
    18201 (p1793)
    17114 (p0730)
    thanks
  2. Re: A6 2.5tdi sport fault code pls help
    Aug 2009
    Manchester, England
    Hi there,
    well the faults are for...
    18226 P1818 Pressure Contr.Solenoid 2 Electrical
    Could not find any info on this code.
    18201 P1793 Output Speed Sensor 2 Circ. No Signal
    Could not find any info on this, but imagine its linked to engine speed and gearbox speed.
    17114 P0730 Gear Incorrect Ratio
    Found this...
    Possible Symptoms:
    Malfunction Indicator Light (MIL) ON
    Possible Causes:
    Transmission Fluid contaminated
    Transmission faulty (Mechanical Problem)
    Possible Solutions:
    Check Transmission Fluid (Color and Contamination)
    Replace Transmission Fluid when necessary
    Check Transmission Mechanics
    What fault are you experiencing with the car?
  3. Re: A6 2.5tdi sport fault code pls help
    Jul 2009
    kent
    thanks for the info.... i haven't actually driven the car as it needed some bodywork done. Just found a piece of paper in glove compartment with these fault codes written on it. enginement management light isn't on so hope these were fixed by previous owner... car should be on the road hopefully next week so will keep u posted... Need to sell my saab 9-3 petrol as well as i have bought the a6 to replace it... Hope i have done the right thing as this is a cvt model
  4. Re: A6 2.5tdi sport fault code pls help
    Jul 2009
    kent
    Oh no... i think i have some cvt issues... car drives like its stuck in gear .. it wont go above 20mph.... do u think gearbox may need servicing i.e fluid change e.t.c
  5. Re: A6 2.5tdi sport fault code pls help
    Aug 2009
    Manchester, England
    It is definately worth while checking the fluid if possible and see if there are any more fault codes on the car. Worst case it could be gearbox ECU or possibly box itself
  6. Re: A6 2.5tdi sport fault code pls help
    Jul 2009
    kent
    took car to a gearbox specialist and just been given a £2k bill for a recon gearbox, new ecu and new clutch .
    car has full service history with Audi showing trans oil was change twice (37k, 78k) . can i reclaim back part of this cost from audi uk. current mileage is 96k, its an 04 reg 2.5tdi cvt
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  3. Please Help Fault code "Emmissions Workshop!
    By AndyJug in forum Chat - Anything with wheels
    Last Post: 08-10-2008, 04:36 PM
  4. The new Audi A6 Avant
  5. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
