Thread: Audi A6 1999 Avant Rear Cigarette lighter fuse??
  1. Audi A6 1999 Avant Rear Cigarette lighter fuse??
    Sep 2008
    Hi everyone,
    I'm trying to locate the fuse for the boot cigarette lighter socket on my 1999 A6 Avant - It is not fuse 33 in the RHS of the dash - that only fuses the front socket.
    Any ideas please??
  2. Re: Audi A6 1999 Avant Rear Cigarette lighter fuse??
    Jan 2009
    Winchester, Hampshire, U.K.
    In their wisdom, Audi have fitted the fuse you're after in the '8 position relay carrier' which is located in the R/H side of the driver's footwell. You'll need to remove the 'Driver's storage compartment' (panel) below the steering wheel. There are 5 screws holding this in place. 2 of them are behind the panel immediately above the steering column, which just pulls away from the dashboard toward the steering wheel & 1 is accessed behind the fuse box cover on the R/H side of the dash. The other 3 are in more easily accessible positions. Drop down the panel, unplug the connector to the footwell light & unclip the diagnostics socket by squeezing together the 3 clips. The fuse is a 20A (yellow) & is clearly visible on the relay carrier.
    HTH
    Dave
  3. Re: Audi A6 1999 Avant Rear Cigarette lighter fuse??
    Sep 2008
    Great thanks Dave - What were they thinking!!
  4. Re: Audi A6 1999 Avant Rear Cigarette lighter fuse??
    Oct 2010
    Bristol, UK
    Hi Dave
    Is it the same in my 52 plate A6 2.5 Tdi Avant ?
    I have power to front socket and the one in the boot but not to the centre one in the console in the rear set - I wasn't aware it was even a separate fuse - assumed it was a wiring fault
    Tks
    John B
  1. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  2. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  3. Replies: 0
    Last Post: 05-03-2006, 07:58 PM
  4. AUDI S LINE SPORTS RANGE RAISES ITS GAME
    Last Post: 01-12-2005, 08:52 PM
  5. New A6 to dominate Audi stand
    Last Post: 23-06-2004, 11:19 PM
