Thread: KI.15 supply (control unit)
Results 1 to 10 of 15
  1. KI.15 supply (control unit)
    Sep 2007
    Plymouth
    On my the panel which covers the fuses, there is a sticker which tells me that fuse 5 is KI.15 supply (control unit)
    Would anyone know exactly what this relates too on a 2003 A6 Avant 1.9tdi? I'm thinking the comfort control module - is that under located under the passenger seat?
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  2. Re: KI.15 supply (control unit)
    Sep 2007
    Plymouth
    Anyone?
  3. Re: KI.15 supply (control unit)
    May 2007
    knee deep in clunge
    13 Post(s)
    ignition supply 15 from the ignition switch me thinks
  4. Re: KI.15 supply (control unit)
    Sep 2007
    Plymouth
    Hm OK, thanks.
    Fuse 5 blows instantly ignition switched on - I'll have a prod about later, but do you think maybe faulty ignition or just a bad connection/wire somewhere?
    1 1 0
  5. Re: KI.15 supply (control unit)
    Tell us the engine code. However is this is F5 left end fuse second row and an AVF engine it is the supply to the Air Con regulator valve and control unit. 10 amp. Regards Peter
  6. Re: KI.15 supply (control unit)
    Sep 2007
    Plymouth
    It's an AWX. I've disconnected a load of equipment linked (according to handbook) to that fuse, including the air con compressor, but of course no joy.
  7. Re: KI.15 supply (control unit)
    Same car (mine is an early 05 model) same label on the fusebox cover. Here is a list I've found.
    Seat heating, bulb monitoring device, mirror switch, mirror adjsutment motors, air conditioner, aux heater, rear roller blind, control unit for parking aid, nav system, telematics, self levelling suspension, tyre press monitor and auto gearbox (tip switch).
  8. Re: KI.15 supply (control unit)
    May 2007
    knee deep in clunge
    13 Post(s)
    You need a current flow diag to trace back your short to earth and its relation to terminal 15 ignition supply,instead of replacing the fuse put a voltmeter across the fuse or 12 volt test light and unplug the circuit until the voltage drops to isolate the short
    2 1 0
  9. Re: KI.15 supply (control unit)
    F5 powers the
    Control and Display unit for the A/C.
    N280 the compressor pressure regulator valve
    G238 The air quality Sensor
    G65 the High Pressure Sendor
    Regards Peter
    1 1 0
  10. Re: KI.15 supply (control unit)
    Sep 2007
    Plymouth
    The offending culprit is the pressure sensor switch and has been left unplugged until the new one arrives.
    At least the fuse has stopped blowing and everything else is back to normal.
  1. Please Help A4 2001 Climate Control Unit
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2009, 05:11 PM
  2. Please Help Battery + Climate Control Unit + Engine + What's next?
    Last Post: 02-05-2009, 07:39 PM
  3. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
