Thread: KI.15 supply (control unit)
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: KI.15 supply (control unit)
    Dec 2012
    Burton On Trent
    Quote Originally Posted by Clinterous View Post
    The offending culprit is the pressure sensor switch and has been left unplugged until the new one arrives.
    At least the fuse has stopped blowing and everything else is back to normal.
    hi there, my A6 02 plate, is doing the same thing, are there any picture references to the details you have described? (electrics are not my strong point)..
  2. Re: KI.15 supply (control unit)
    Jun 2017
    US
    Hm OK, thanks.
    Fuse 5 blows instantly ignition switched on - I'll have a prod about later, but do you think maybe faulty ignition or just a bad connection/wire somewhere?
    Im in same boat. Stumped. I have gone over tons of wires n spots. Driving me nuts. Also hazards n door locks go off 10x like crazy when super cold out.
    Sent from my SM-G955U using Tapatalk
  3. Re: KI.15 supply (control unit)
    Jun 2017
    US
    Hm OK, thanks.
    Can you give me any ideas to how you resolved your issue. I'm busting my brain and patience dealing wit this fuse. I've gotten it to not blow... but shortly into driving it then again blows. I've had a number of other crazy things happen to me since this issue.
    This fuse became a issue after engine replacement by a friend of mine I was not there to help him much but I feel maybe he cause a short to ground n have chkd all front end wires besides the one to a.c. compressor valve on the compressor n oil temp sensor if my 2000 2.7t has one on the upper oil pan which IDK.
    I've checked everything simple... I'm dieing with no heat n a.c.
  4. Re: KI.15 supply (control unit)
    Feb 2019
    Keith
    I have the same problem on that A6 1.8 t c5 no ac and would this have eny thing to do with the starter I replaced the clutch and the starter is dead power going to it but nothing from the key the dash lights up as it should any help would be a massive help thank you
  5. Re: KI.15 supply (control unit)
    Aug 2017
    West Midlands UK
    11 Post(s)
    Is this the switch that screws into the air-con piping between below the O/S headlight and air-con rad? G65?
    If so mine was showing as being the fault on my AC with VCDS but it hasn't cured it by changing it, wasn't blowing the fuse though.
    2003 A6 C5 2.5 TDI Quattro Avant (180bhp)
  1. Please Help A4 2001 Climate Control Unit
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-05-2009, 05:11 PM
  2. Please Help Battery + Climate Control Unit + Engine + What's next?
    Last Post: 02-05-2009, 07:39 PM
  3. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
