Thread: Front brake knocking after new pads installed
  1. Front brake knocking after new pads installed
    May 2009
    Bacsalmas
    Please help!
    I just replaced my front brake pads and resurfaced the discs I marked the discs left right so i put them back to the same side.
    Now when I brake i hear a very loud clicking/knocking noise from the front drivers side(left) wheel. Sounds like someone hitting the disc with a hammer. not like an ABS sound. No other noise when I am not touching the brake pedal. I need to leave on Friday for a long road trip. Please help me with ideas!
    Thanks!!
    BTW I have a 1999 Passat 1.9 TDI
  2. Re: Front brake knocking after new pads installed
    Norfolk
    Check the pads are not loose and rattling in the caliper.
  3. Re: Front brake knocking after new pads installed
    Jun 2006
    UK, Mids
    Did you refit the retaining clip/spring? Are they definitely the correct pads? Sounds like the pads are jumping about.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Front brake knocking after new pads installed
    May 2009
    Bacsalmas
    Quote Originally Posted by snapdragon View Post
    Pads are rock solid the clip is in the correct position.
    I just got another reply from a different source and they said I should have not resurfaced the rotors. They said this is a common mistake with these cars and this is the result. can be true??
  5. Re: Front brake knocking after new pads installed
    Norfolk
    Resurfacing shouldn't make any difference unless the rotors are too thin, but that won't show until the pads are well worn. Perhaps the rotors were not resurfaced properly. They do have to be very flat with zero run-out.
  6. Re: Front brake knocking after new pads installed
    Jul 2008
    I would still go with pads moving..
  7. Re: Front brake knocking after new pads installed
    May 2009
    Bacsalmas
    Just put new discs on and problem solved!
    Weird thing. Never seen like that.
    Thanks for the replies anyway!!!
  1. Brake squeal on new front pads?
    By jonbaker in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 01:18 PM
  2. Green Stuff Brake Pads
    By M53494 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-04-2008, 01:18 PM
  3. VW Polo Front brake pads - Advice Please
    By liuc in forum Chat - Anything with wheels
    Last Post: 20-10-2007, 02:22 PM
  4. At home on all roads and tracks - Audi A6 allroad quattro
