Thread: 2002 Sharan 1.9 TDi Intermittent power loss.
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. 2002 Sharan 1.9 TDi Intermittent power loss.
    Dec 2007
    Montrose Scotland
    Occasionally, and probably only under load, the 1.9 TDi loses power. You can be happily driving along on a motorway for 2 hours then with no warning the car loses the power, I assume its a limp mode as the car will still drive on but with less response.
    Anyway, turn off the ignition and it resets. THen maybe 2 hours later, the same again, or it could be every 15 mins for a brief spell, there is no timing period for how often it happens.
    This initially happened about 4 years ago and upon reaching my destination some 3-400 miles away with the fault occurring a couple of times I realised that the back box had parted. I assumed it was a back pressure that had caused it? Anyway, no more faults until this year. Same again (not the back box) but the fault is there.
    So..... suggestions please?
    Its done 88K and nothing serious has been replaced.
  2. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    I would suggest a fault code read,
  3. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    Dec 2007
    Montrose Scotland
    Fault code reads:
    17965 Charge Pressure Controller Positive Deactivation P1557-35-10 Intermittent.
    Problem has now progressed, 90% of the time it is like driving a car without a turbo.
    So, is it....
    The MAF? Tor the Turbo actuator arm sticking?...OR the Turbo itself?
    Garage beckons tomorrow.... Timing Belt was due anyways
    Having done a bit more reading, I am guessing the Turbo, possibly the variable vanes sticking.
    Does anyone have experience of stripping and cleaning these, can it be done without a replacement?
  4. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    May 2009
    Leeds
    If you are still on your original air mass sensor then I would suspect that may be failing given its age and mileage. If it sometimes works perfectly then that at least rules out mechanical wear - which is a lot more expensive to fix!
    Good luck
  5. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    Dec 2007
    Montrose Scotland
    Thats what I am hoping given the price of turbos.
  6. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    Dec 2007
    Montrose Scotland
    Ok, Turbo replaced, as per garage recommendations
    MAF meter swapped out for a mates with no difference.
    C*ap!
    Gutted.
    On the plus side, I now know its a pretty easy job to replace the turbo.
    Latest code?
    17964 - Manifold Pressure Sensor (G71): Open/Short to Ground
  7. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    Dec 2007
    Montrose Scotland
    Does anybody know the name of the electrical valve that controls the vacuum line to the turbo?
    It is mounted on the bulkhead behind a heatshield in the engine bay.
    Last chance saloon as everything else appears to be working.
  8. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    Charge pressure control solenoid valve -N75-
  9. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    Dec 2007
    Montrose Scotland
    thank you
    Can this be sourced anywhere other than VW? Or is it a VW only part?
  10. Re: 2002 Sharan 1.9 TDi Intermittent power loss.
    Dec 2007
    Montrose Scotland
    Kenney, What's the other valve there called?
  1. Cleaning the turbo & power loss A4 1.9 tdi AFN engine 1999
    By fantasiagreen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-09-2010, 12:58 AM
  2. Power loss problem with 1997 A4 1.9 TDI
    By john davis 100 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-10-2009, 08:52 AM
  3. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  4. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  5. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
