Thread: Faulty ABS Module
  1. Faulty ABS Module
    Aug 2009
    northampton uk
    I had a problem with the ABS module. The ABS & ESP light was on and when the engine was restarted, they went off.
    When connected to diagnostics kit, there was no errors.
    The ABS module & pump was replaced with a second hand one and the lights came on.
    When connected to diagnostics kit, it showed 2 faults, steering angle sensor and coding error.
    The ABS module & pump was replaced with the old one and the same 2 faults occured.
    I have been advised to take it to VW to recode the module. Is this correct or can anyone out there help me with this frustrating issue?
  2. Re: Faulty ABS Module
    If you can read the coding from the old unit,and recode the new unit with it,it could help.You need to preform a basic setting of the steering angle sensor
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. A4 B5 2.5 Tdi Saloon - ABS system Bleeding ?
    By kevmayer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2009, 05:30 PM
  3. Replies: 0
    Last Post: 30-03-2008, 02:46 PM
  4. ABS light Issue
    By gnasher in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-01-2008, 08:32 PM
  5. ABS control module 1998 VW Passat GLS 1.8L turbo
    By adrian537 in forum Chat - Completely Off Topic
    Last Post: 13-11-2007, 11:02 PM
