Thread: Limp home mode
  1. Limp home mode
    Hi would appreciate some help!
    Have been having problems with my Audi A4 115 bhb going into limp home mode. Has recently had a replacement MAF sensor and Turbo but still doing it and starting to drive me mad, any suggestions, help would be grealy appreciated.
  2. Re: Limp home mode
    Apr 2009
    Have you had it diagnosed? Do you have a fault code?
  3. Re: Limp home mode
    Hi, the garage did a diagnosis that indicated the turbo had failed but I don't have the codes.
  4. Re: Limp home mode
    Apr 2009
    Unfortunately without a fault code there is probably little point in anyone trying to give advice.
    I take it that your car is a 1.9 turbo diesel? If so there are a lot of niggly little problems that can occur that will put your car into limp mode. A lot of garages will incorrectly diagnose turbo failure and replace at great cost when the problem can be as simple as a leaking vacuum hose.
    You really need to get a fault code diagnosis. Personally as the garage has replaced the turbo then I would be going back there and telling them to sort the problem Free Of Charge.
  5. Re: Limp home mode
    Will have to get those codes, Garage have agreed to re look at the car, they are a trustworthy garage.
  6. Re: Limp home mode
    Apr 2009
    Once you have the codes then post them up and someone will be able to tell you what fault they indicate.
    I am guessing that you will have had codes either 17964 or 17965, which indicate an underboost or overboost condition, and lead some garages to diagnose a blown turbo.
    These faults are common on the 1.9 tdi, but it is normally a simple fix when you have found the fault.
    I am not disputing that your garage is trustworthy, however I would imagine that a turbo replacement has cost you several hundred pounds and you still have a faulty car. My A4 was in permanent limp mode for 6 months. A good local independant diagnosed a blown turbo and quoted 850 for replacement. I knew that the turbo was ok, and after going through every part of the car I found that the cat had fell apart and was blocking the downpipe. I decatted it and it goes like a rocket, and I am 850 richer.
  1. Engine Management Light and Limp Home Mode
    By gianni67 in forum Beetle 2000-
    Last Post: 30-04-2009, 08:51 AM
  2. A4 1.9 tdi in Limp Home mode after high power.
    By saidtheape in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2009, 01:10 PM
  3. Tiptronic Limp Home Mode
    By ddreeves in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2008, 07:31 PM
  4. GT TDi 115 Limp Home Mode
    By MikeMc in forum Golf MK4 - 1999 - 2004
    Last Post: 21-01-2008, 02:55 PM
  5. 120kph and turns into a slug= limp home mode ??
    By golfergve in forum Archive posts
    Last Post: 07-08-2007, 02:16 PM
