Thread: Need help security access Audi A3 8P
Results 1 to 10 of 10
  1. Need help security access Audi A3 8P
    Aug 2009
    France
    Hello every one,
    i need to adapt the Engine rpm on my Audi A3 8P (model 2LTDI 140 BKD engine , october 2003)
    I have the security code 30475, but this code doesn' t work on my car,
    Is there anybody who can help me with the good code ?
    Thanks a lot
  2. Re: Need help security access Audi A3 8P
    Nov 2008
    folkestone.kent
    where did you get that code from ?
  3. Re: Need help security access Audi A3 8P
    Aug 2009
    France
    i get that code here :
    http://wiki.ross-tech.com/index.php/Main_Page
    Someone can help me ?
  4. Re: Need help security access Audi A3 8P
    Ambler, PA, USA
    The code you posted is a login code for making changes. It is not the PIN/SKC for the car. The PIN/SKC on an Audi A3 8P can only be retrieved by a shop using the factory tool and with access to the factory computer. I am not aware of any aftermarket tool that can get the PIN/SKC for the 8P chasis. Anyone out there who knows they can do it?
  5. Re: Need help security access Audi A3 8P
    Aug 2009
    France
    Quote Originally Posted by bearthebruce View Post
    Are you sure?
    i thought that the PIN/SKC is only for coding keys ?
    On the function security access, i think it' s just a 5 characters code no ?
    The pin is 7 characters no ?
  6. Re: Need help security access Audi A3 8P
    Mansfield, UK
    I can retrieve SKCs Bruce/OP however I'm not sure you require that to change the idle speed. Will look into it a little later.
  7. Re: Need help security access Audi A3 8P
    Mansfield, UK
    Try 12233 instead of 30475.
  8. Re: Need help security access Audi A3 8P
    Ambler, PA, USA
    I don't know what drugs I was doing yesterday! No, you do not need the SKC/PIN to do the adaptation for changing the RPM. I was looking for the login code but can't find the info here at home. If the 12233 doesn't work, post again and I'll try to find the login at work today.
    Sorry for being such a dweeb!
    0 0 1
  9. Re: Need help security access Audi A3 8P
    Aug 2009
    France
    Ok Thanks guys !
    I ll try tomorow and let you know quiclky !
  10. Re: Need help security access Audi A3 8P
    Aug 2009
    France
    Hi Guys !!
    Just want to tell you Thanks,
    I have done it today, the code is OK !
    And to adapt the iddle speed, we need a secutity access !
    One more time thanks,
  1. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  2. Audi Cuts New A3 Engine Down To Size
    Last Post: 14-08-2007, 10:18 PM
  3. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
  4. World's largest Audi centre opens on a high note
    Last Post: 29-11-2004, 08:51 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
