Thread: vw golf gti no acceleration past 3000 revs
Results 1 to 9 of 9
  1. vw golf gti no acceleration past 3000 revs
    Jul 2009
    Skewen, Wales
    I have a mk3 16v 2.0 volkswagen golf 1997 (p reg). What started as an intermittent fault is not continuous. When accelerating in any gear just before it hits 3000 revs the car pulls back and starts spluttering and will then not accelerate past approx 40-50mph. I have changed the following trying to fix this fault:- air flow sensor, ignition leads, distributor cap, spark plugs, oil, oil filter, air filter, fuel filter. I have taken the car to 3 different garages and none of them can find the fault. The last garage changed the ignition switch and the coil pack but the latter made no difference so have kept the old one on. They also tested the car when cold then when hot and it did not make any difference to the fault. The car has been on a diagnostics computer twice, the first time was an air intake fault hence the reason i changed the air flow sensor but the second time did not bring up any fault at all. Any advice would be gratefully appreciated as i am desperate to make my beloved car work. Thankyou.
  2. Re: vw golf gti no acceleration past 3000 revs
    Nov 2008
    folkestone.kent
    change the engine control relay (number30) or no3 relay in the fuse box if my memory is correct,these have a tendency to play up and give the faults you describe worth a try for a tenner from the dealers
  3. Re: vw golf gti no acceleration past 3000 revs
    Jul 2009
    Skewen, Wales
    thankyou so much for this information, i bought the no30 relay from the dealer yesterday for £12.42 and it fixed the problem immediately. You are a genius. Many thanks again. Ruth
  4. Re: vw golf gti no acceleration past 3000 revs
    Nov 2008
    folkestone.kent
    that relay causes maaaaaaaaaany problems pleased its sorted....good luck and happy motoring
  5. Re: vw golf gti no acceleration past 3000 revs
    Aug 2009
    kidwelly
    Hi there, IM having similar problem to ruth with my 8v golf gti mk3. Pulls well up to 3000 rpm and then dissapoints me. doesnt splutter or judder at all just doesnt pull as hard. Do you think changing that relay mite do it. What was relay called again. Be greatfull for any advice given. Thanks
  6. Re: vw golf gti no acceleration past 3000 revs
    Nov 2008
    folkestone.kent
    could be its position 4 i think with number 30 on it ,for what they cost its worth a go
  7. Re: vw golf gti no acceleration past 3000 revs
    Dec 2008
    Kent UK
    I keep relays and MAF's as part of my toolkit. You can never have to many of them, especially seeing as you can put them in your pocket at the breakers yard......Whoops.........Did I say that out loud.....?
  8. Re: vw golf gti no acceleration past 3000 revs
    Jun 2017
    uk
    What happens if there isn't a relay 30 .. also this is under the steering wheel side.. on a mk3 cab..94 ..
  9. Re: vw golf gti no acceleration past 3000 revs
    1840 Post(s)
    Start a new thread please, this one is a decade old and relates to a different engine.
  1. Golf Mk4 GTI 150 Sticking Revs
    By littlecham in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2010, 11:46 AM
  2. High Revs on 1993 Golf GTI 2.0 8v (2E)
    By ctwomey in forum Golf MK3 - 1993 - 1999
    Last Post: 03-05-2009, 11:08 AM
  3. VW Golf GTi Mk3 permanent ABS warning light
    By macka in forum Golf MK3 - 1993 - 1999
    Last Post: 28-05-2007, 11:19 PM
  4. Volkswagen Unveils Golf Gti W12-650 Design Study
    Last Post: 22-05-2007, 08:24 PM
  5. Engine Diagnostic Light VW Golf 1.8T GTI
    By gmc in forum Archive posts
    Last Post: 04-04-2007, 05:21 PM
