Thread: oil pressure
  1. oil pressure
    Jul 2009
    swansea, wales
    I have a 1991 non turbo 1.9 Diesel Transporter. A few weeks ago it dropped a valve and destroyed a hydraulic lifter, I assume there was a lack of oil pressure to the head, I did get the odd beep warning before it happened but nothing constant. On fixing the head and fitting new belt, gasket etc I still had low oil pressure so have changed the pump. The pressure builds at the filter sensor but drops after a few mins, hardly any pressure at the top of the block sensor point. Cooler is coming out next. Any ideas? I'm thinking check cooler/filter although filter is new, then it has to be oil channels or bearings right? No huge knocking so thought it not the bearings but ?????
  2. Re: oil pressure
    I think you need to drop the sump and check the bearings
  3. Re: oil pressure
    Jul 2009
    swansea, wales
    That's what I'm starting to think, any quick way of telling if they're cooked?
  4. Re: oil pressure
    A sharp experienced ear,might be able to hear,if the main bearings are noisy,otherwise,no,and you got to start somewhere
  1. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  2. Answers from an oil expert...
    Last Post: 20-01-2008, 05:30 PM
  3. Answers From The Oil Expert Part 2
    Last Post: 22-10-2007, 08:30 AM
  4. Answers From The Oil Expert
    Last Post: 22-10-2007, 08:28 AM
