Dear all,
First of all i would like to say hello to all of you, this is my first post in the forum.
Anyway,
My car alarm started going off for no reason a few days ago, no matter what i did to it, it would not shut up. I tried all sorts, but it was the simplest method that made it go quiet, leave the car unlocked
The signal lights would not come on when i tried to lock the car, the signal lights do not come on when the alarm is set off, the alarm would activate itself and go straight to SHOUTING mode.
So i came here and registered yesterday, started reading and found that there were other cases like mine. Apparently has something to do with water leaking into the ECU and compromising the alarm system.
Today, i sent the car to the dealers, (bedford) and after they run the diagnosis i was told that:
Alarm Horn defective due to water ingeress in alarm connector.
Found Faults in System, Convenience ECU Defective.
Requires new ECU, Alarm Horn and Wiring Repair on N/S a piller to rectify.
All in all, they told me it would cost a whooping £500.00
But that's just to expensive, and for a factory fitted alarm!!
So, is there anyway i can do a fix of this myself or is there a cheaper way??
PS, can i disable the alarm but still be able to lock the doors at night without the alarm waking the neighbours????
Thanks in advance
