Thread: Passat B6 2.0 TDI hot starting issue
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. Re: Passat B6 2.0 TDI hot starting issue
    #21
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by freebird69 View Post
    I have a 2005 Passat B6 2.0 TDI that is difficult to start when the engine is at normal running temperature. It catches on first crank but when you release the starter, just cuts out ... if you hold the starter for several cranks, it will eventually start. When the engine is cold or has just been stopped in last few seconds, it starts ok. I'm guessing there's a temperature sensor somewhere that's mis-reading though not completely failed as there is no engine management malfunction indicator showing. The vehicle also seems to run ok when hot. Does anyone know the likely cause?
    Also, can there be fault codes accessible to a vag-com but don't light the malfunction indicator?
    Sounds like leaking injector, that creates hydrolock effect.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  2. Re: Passat B6 2.0 TDI hot starting issue
    #22
    Jan 2018
    Bucharest
    Sorry freebird69! But the English is not my native language. You "flogged it" it means that you did not find a solution?
  3. Re: Passat B6 2.0 TDI hot starting issue
    #23
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by Ovideus View Post
    Hi, it means he sold his car, which means he got rid of the problem by getting rid of the car. To 'flog' in (bad) English means to sell.
    Q.
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: Passat B6 2.0 TDI hot starting issue
    #24
    Jan 2018
    Bucharest
    Quote Originally Posted by Quatrelle View Post
    Q.
    Thank you very much for the explanation.
  1. My first impressions of my GT TDi Golf
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2009, 05:42 PM
  2. Question Passat 2.0 Tdi MPG
    By pendle wizard in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2009, 10:38 PM
  3. New Highline Model Adds Value Boost To Passat Range
    Last Post: 13-02-2008, 08:13 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
