Thread: T4 Sump removal
  1. T4 Sump removal
    Jun 2009
    king's lynn
    I've removed all visible bolts and the sump moves around but still seems trapped at the bell housing end although it wiggles.
    Do I need the crankshaft pulley off or are there any hidden bolts. We got the bolt out above the driveshaft housing with difficulty but its still stuck.
    Please help. Simon
  2. Re: T4 Sump removal
    You do not have to remove the pulley,What about the two bolts to the rear of the sump,the flywheel must be in a certain position to access them,otherwise you can not see them.
  3. Re: T4 Sump removal
    Jun 2009
    king's lynn
    Thanks Kenny
    I can't look now as its dark but I don't understand. Where can you see the flywheel without removing the bell housing. Simon
  4. Re: T4 Sump removal
    There are 2 recesses in the sump,you will need a long allen key,
  5. Re: T4 Sump removal
    Jul 2009
    swansea, wales
    This happened to me, the baffle was gasket glued onto the sump you have to take a sharp scraper or screwdriver and separate the two then the sump falls off leaving the baffle hanging off the pump.
  1. LT35 sump removal help please!!
    By hooheehaa in forum The Commercial Range
    Last Post: 20-09-2009, 09:43 AM
  2. Please Help Stuck with 1.8 T sump removal
    By Penfold4140 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-08-2009, 01:10 PM
  3. LT35 sump removal help please!!
    Last Post: 12-06-2009, 09:21 PM
  4. Please Help Sump Removal - 2001 1.8T Passat
    By Davemsy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2009, 10:24 AM
  5. Oil Drain Plug (or Sump) Removal Problem
    By Chromate in forum Golf MK3 - 1993 - 1999
    Last Post: 05-03-2008, 12:41 AM
