Thread: 1st Locked out, now dead batt - plz help!
  1. Question 1st Locked out, now dead batt - plz help!
    Selston, Nottinghamshire
    Please help.
    Originally, my car would not unlock using the key(s)
    I opened the door manually and set the alarm off.
    i turned off the alarm by stating the car, and the alarm went off.
    i (out of interest) pressed the unlock button many times in succession while the engine was running - lard behold, the key i did this with now unlock the car remotely - phew - stroke of luck.
    now, after 200 miles and 2 days later, the battery is dead - not just any dead, but not charging dead.
    I jumped the car and left it running - did a VAG-COM check, and the alternator is charging excellently - 14.4 with dead bat, and upto 15 with lights on.
    If I leave myt Mk1GTI Golf battery connected the voltage eventually settles down to between 12.4 and 14.0volts.
    Ok, so i guess that my battery is goofed on my 2003 1900 TDI Quatt. Sport 130ps.
    Although say that, i get a bit of a crack off the battery when i disconnect it!.
    My VAG error codes are attached - could someone please help me with "steering Angle Sensor" - what is it??
    Please help!! my car is inits infancy with 140,000 on the clock!!
    Chassis Type: 8E - B6 Audi A4
    Address 01 -------------------------------------------------------
    Controller: 038 906 019 JT
    Component: G000SG 1572
    Coding: 00003
    Shop #: WSC 63251
    WAUZZZ8E53A3xxxx9 AUZ6Z0C0xxxx88
    0 Faults Found:
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04255
    Shop #: WSC 06435
    1 Faults Found:
    01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
    35-00 - -
    Address 08 -------------------------------------------------------
    Controller: 8E0 820 043 AC
    Component: A4 Klimaautomat 1119
    Coding: 00000
    Shop #: WSC 63251
    0 Faults Found:
    Address 09 -------------------------------------------------------
    Controller: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00101
    Shop #: WSC 63251
    0 Faults Found:
    Skipping Address 15-Airbags
    Address 16 -------------------------------------------------------
    Controller: 8E0 953 549 N
    Component: Lenksáulenmodul 0308
    Coding: 00022
    Shop #: WSC 63251
    0 Faults Found:
    Address 17 -------------------------------------------------------
    Controller: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D36
    Coding: 01400
    Shop #: WSC 00503
    0 Faults Found:
    Address 45 -------------------------------------------------------
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    1 Faults Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Address 46 -------------------------------------------------------
    Controller: 8E0 959 433 BC
    Component: Komfortgerát T3B 1211
    Coding: 07115
    Shop #: WSC 06435
    2 Faults Found:
    00957 - Key 3
    35-10 - - - Intermittent
    01403 - Glass-Break Sensors: Rear
    36-10 - Open Circuit - Intermittent
    Address 56 -------------------------------------------------------
    Controller: 8E0 035 195 P
    Component: symphony II NP2 0152
    Coding: 01001
    Shop #: WSC 00523
    0 Faults Found:
    End -----------------------------------------------------
    Many, Many thanks in advance!!
    Wayne.
    History of V.A.G. Cars Owned:-
    2001 A4 Avant SE AJM 1.9 TDI -2011 A4 Avant SE 140PS 2.0 TDI - 2005 BXE VW Passat 100PS Highline 1900 TDi - 2006 Touran 1900TDi 105PD - 2003 Audi A4 1.9TDI Avant Quattro Sport
    2003 Audi A4 1.9TDI Saloon Quattro Sport - 1983 VW Golf GTi 1800 Mk1 - DX - 1978 VW Golf GTi 1600 MK1 (LHD Import) - EG(00004) - 1978 VW Polo N
  2. Re: 1st Locked out, now dead batt - plz help!
    http://www.meeknet.co.uk/E38/E38_Ste...gle_Sensor.pdf this will give you an idea what a G85 is
  3. Re: 1st Locked out, now dead batt - plz help!
    Thanks for that, it makes interesting reading!
  4. Post Re: 1st Locked out, now dead batt - plz help!
    Just bought a Bosch S5 battery for 49.99 + Vodka and Tonic.
    gonna go for a run and see what error codes remain.
  1. A3 Radio cassette player dead?
    By ssangha99 in forum Audi A3 - Archive Topics
    Last Post: 10-04-2008, 02:57 PM
  2. 1st gear
    By paresh1uk in forum Chat - Anything with wheels
    Last Post: 14-11-2007, 05:31 PM
  3. Ignition left on until battery dead!
    By michaelab in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 12:56 PM
  4. my door just stays locked
    By diljaa in forum Golf MK4 - 1999 - 2004
    Last Post: 05-12-2006, 05:48 PM
