Thread: Airbrush painting
Results 1 to 8 of 8
  1. Airbrush painting
    Nov 2008
    Basingstoke
    Hi All,
    I wonder if anyone here can help. I'm trying to paint an RC model at the moment but I'm running in to a small problem. Using cans I can put the base paint on without a problem and I can put the colour on using cans, but I wanted to use my airbrush and a different colour.
    When I try to paint using acrylics or water based paint what I end up with is a speckled pattern.
    What am I doing wrong?
    Many thanks,
  2. Re: Airbrush painting
    1841 Post(s)
    I am no expert but I do a lot of model making and use an Iwata TR1 air brush. From what you say you have the paint too thick. What paint are you using, Tamiya acrylic?
  3. Re: Airbrush painting
    Mar 2009
    Gillingham Kent
    Sounds like one for Crasher, he is the model building expert
    Edit: This happens when idiots at work get clamped when im halfway through a post
  4. Re: Airbrush painting
    Nov 2008
    Basingstoke
    Yes, tamiya paint. I've been mixing it 1 part paint to 3 parts thinner. What would you reccomend?
  5. Re: Airbrush painting
    1841 Post(s)
    That’s a bit thin. Which air brush and what air pressure are you using?
  6. Re: Airbrush painting
    Nov 2008
    Basingstoke
    The brush is a Revell Standard 39101 and I've got a Revell compressor 39136 which does up to 3 bar. I've tried various settings but just can't get this right for some reason.
  7. Re: Airbrush painting
    1841 Post(s)
    try 1 bar and thinning it 1:1.
  8. Re: Airbrush painting
    Nov 2008
    Basingstoke
    Okay, I'll give that a go.
    Many thanks,
    David
  1. A6 - painting hubs n calipers
    By JimC64 in forum Body Work, Body Styling and Body Kits
    Last Post: 30-04-2012, 12:31 AM
  2. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  3. Painting ABS Plastic
    By orr_niall in forum Golf MK3 - 1993 - 1999
    Last Post: 07-04-2009, 11:00 PM
  4. Painting the bodywork
    By Rav in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-05-2008, 09:20 PM
  5. Painting Brake Calipers for VW's
    By Shipz in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-06-2007, 08:44 PM
