Thread: 1.8L tt Overheating
Results 1 to 10 of 15
  1. 1.8L tt Overheating
    Jul 2009
    jacksonville florida united states
    I have a 2002 1.8L TT while driving or idling the fans will not come on and the car overheats if you turn on the A/C the fans come on. Could it be the fan relay? If so does anyone know where it is?
    I have tried to get the code since the check engine light is on also but the OBD would not read them I guess it has some kind of CAN protection.
    Any help would be apprieciated
  2. Re: 1.8L tt Overheating
    Have u checked your water pump impella as it is a know fault on these
    RED SEAT LEON CUPRA WITH REVO REMAP 196bhp AND 241lb TORQUE
  3. Re: 1.8L tt Overheating
    Jul 2009
    No, How do you check them?
  4. Re: 1.8L tt Overheating
    which model do u have and what engine code. Will be one of these below
    ajq
    app
    apx
    ary
    aum
    auq
    bam
  5. Re: 1.8L tt Overheating
    Jul 2009
    It si a 1.8L 5V Turbo the only thing that I see on the motor is AWP is there some other place I should look?
  6. Re: 1.8L tt Overheating
    Jul 2009
    The AWP stamped on a tab on the cylinder head. Is there another place I should look. This does not match with any of the codes listed. Is one engine code more prone to problems than others?
  7. Re: 1.8L tt Overheating
    Jul 2009
    Quantum Performance says it should be AUQ/ARY but I do not see anything that has this on it.
  8. Re: 1.8L tt Overheating
    Check operation by
    take expansion cap off and crank it up and let it run until it gets to operating temp. You should be able to see the coolant moving inside the expansion tank. if it is, it's working.
  9. Re: 1.8L tt Overheating
    Jul 2009
    OK it works.
  10. Re: 1.8L tt Overheating
    Southern County Softy
    20 Post(s)
    Does the top and bottom hoses on the rad both get hot.
    You could have a jammed thermostat
    A4 2.5 tdi QS (mapped)
  1. Replies: 0
    Last Post: 17-05-2007, 08:08 PM
  2. Prized Top Gear Award For New Audi TT Coupé
    Last Post: 18-12-2006, 08:54 PM
  3. Audi Airs New Open-top TT for Summer 2007
    Last Post: 18-10-2006, 07:02 PM
  4. Power born from passion The new Audi TT Coupé
    Last Post: 16-06-2006, 07:30 PM
  5. Power boost for Audi TT models
    Last Post: 06-08-2005, 07:46 PM
