Thread: B5 A4 Central Locking FAQ
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 77
  1. Re: B5 A4 Central Locking FAQ
    Jul 2008
    stoke on trent
    8L0862257A and 8L0862257H are non remote pumps all other suffix found on uk spec cars are remote compatable
    i think remote c/l was an option on A4's untill facelift model, they have 8d0862257'e' p/n
    you can use a 'G' to replace a 'H' but remote range is poor
  2. Re: B5 A4 Central Locking FAQ
    Nov 2008
    Thanks for that.
    Maybe this post should be revised so as not to give the wrong information to people who might go out and spend 50 odd quid on a remote fob only o find out that they need a new pump!!!!!
  3. Re: B5 A4 Central Locking FAQ
    Apr 2007
    Lancashire
    Apologies, there is a lot of pertinent info missing, 4A0 & 8D0 pumps, compatible car-pump-remotes etc.
    On a B5 chassis car, you may be more satisfied with an aftermarket flip-key kit, as the OEM remote only has a range of a few metres (for security reasons).
  4. Re: B5 A4 Central Locking FAQ
    Dec 2008
    East Preston, West Sussex
    Tried to add a new remote today using the info above but no sucess. The hazard lights flashed at the appropriate times, and the new remote did unlock the car when it was still in the door lock, but on removal it would not unlock/lock the car/boot at all.
    Can anyone help me out with this.
    Thanks in advance,
    John.
    1999 A4 B5.5 Saloon
  5. Re: B5 A4 Central Locking FAQ
    Apr 2007
    Lancashire
    From your description it appears that the car did recognise and synch the remote.
    The most likely explanation is either a weak battery in the remote (try operating it inside the car, or with the remote touching the bodywork)
    Or the remote sync proceedure was not completed successfully.
  6. Re: B5 A4 Central Locking FAQ
    Dec 2008
    Well in the end I did get this remote to work ok with the car, but now the original one diesn't, so it looks like I didn't wait the required length of time between pressing the unlock the reqd number of times for the remote, and then the single unlock. Audi service manuals indicate a wait of 5 secs after the initial number of presses of the UNLOCK, before the single UNLOCK. It then says to switch off the ignition and remove the ignition key, then check the new transmitter for function.
    Guess I was just a bit too quick off the mark!
    Thanks for your reply, I will try it again later on.
    John
  7. Question Re: B5 A4 Central Locking FAQ
    #17
    Mar 2009
    Dear reading experts,
    My 1995 Audi A4 has central door locking with remote button thing. (Apologies for bad english, english is not my first language)
    The central door locking works quick and smooth with the keys.
    However, three days ago my car battery died. Nothing electric worked, is was that empty. Merely the LED of the alarm on the dashboard functioned if I press the button.
    The dealer gave me a new battery. Now everything works fine again.
    Apart from the button that does the central door locks.
    It still works with keys. The LED also responds when I press the button.
    Just no flashing indicator lights and door-unlocking.
    What can this be?
    Any help would be greatly apprecieated.
  8. Re: B5 A4 Central Locking FAQ
    #18
    Jan 2009
    I have just had the pleasure of discovering the graphite impeller has shattered in my central locking pump. I can only find a part number of 8LO 862 257. Can someone tell me where I find the letter to finish the part number from? Also does anyone know where I can buy a new graphite impeller from? I don't see the point in replacing the whole pump when it is just the impeller that's broke.
  9. Re: B5 A4 Central Locking FAQ
    #19
    Hi, I have seen the impellers sold as kits on ebay. Not sure if you can get a similar type of pump and take the bits from it, but maybe somone else will answer that.....
  10. Re: B5 A4 Central Locking FAQ
    #20
    Jul 2008
    stoke on trent
    http://cgi.ebay.co.uk/audi-a4-a3-cen...1%7C240%3A1318
    some pumps part numbers dont end in a letter, but one ending in a 'G' will be the same if you want to replace pump
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  1. A6 Central Locking
    By lawsy in forum Chat - Completely Off Topic
    Last Post: 29-04-2008, 08:03 PM
  2. A4 Central locking
    By gre22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-01-2008, 03:08 PM
  3. A6 central locking
    By dixielee in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-07-2007, 10:58 AM
  4. central locking
    By mwill82 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-01-2007, 07:57 PM
  5. a4 central locking
    By graham147 in forum Chat - Completely Off Topic
    Last Post: 30-07-2006, 04:52 PM
