Thread: 01 sharan - funny problem
Results 1 to 10 of 10
  1. 01 sharan - funny problem
    Jun 2009
    norway
    so I installed an aftermarked xenon kit today, and when finished with it I could not lock the car with the remote. took it for a spin and the wipers only worked at full speed. returned ome and opened the bonnet and removed the plugs to the ballasts. now the car is working perfect. locking and wiping. put on one of the ballasts and still everything works well. connected the other too; same problem again. took it off - all ok. either something wrong with the ballast or do I need to put on a resistor to clear this up?
  2. Re: 01 sharan - funny problem
    Apr 2007
    Lancashire
    Are you using a relayed harness drawing directly from the battery, or just pluging the ballasts straight into one side of the factory loom?
  3. Re: 01 sharan - funny problem
    Jun 2009
    norway
    I've plugged it straight to the factory wiring to each headlight.
  4. Re: 01 sharan - funny problem
    Apr 2007
    Lancashire
    Could be a CAN-bus problem, as you suggest you may well have to use 10 ohm / 20W resistors to fool the 'bulb out' (35W HID kit).
    Or coding the car for xenons may prevent the 'bulb out' issue.
    Other EMP weirdness and voltage drop problems should only occur when turning the lights on using the standard factory halogen loom.
    I would purchase a fused, relayed harness to draw direct from the battery and code the car for xenons with vagcom.
  5. Re: 01 sharan - funny problem
    Jun 2009
    norway
    thought I should try to connect it relay so I purchased relay and harness today, I will try connecting through that tomorrow, and vag-com it. where in vag-com can I turn on the factory xenon setting?
  6. Re: 01 sharan - funny problem
    Apr 2007
    Lancashire
    Not to sure on an 01 Sharan, i would try somewhere in 'Central Electronics' first.
    I would try asking Uwe at Rosstech?
    Dont think the coding will need altering as halogen/xenon are standard options.
  7. Re: 01 sharan - funny problem
    There is no coding necessary for halogen or xenon lighting on the 01 Sharan
  8. Re: 01 sharan - funny problem
    Apr 2007
    Lancashire
    Is there not something to stop a 'bulb out' when only drawing 35W?
    I am no Sharan expert. lol
  9. Re: 01 sharan - funny problem
    I beleive that is intragated in the data bus diagnostic interface, in the dash panel insert.
  10. Re: 01 sharan - funny problem
    Jun 2009
    norway
    i connected it directly form the battery and new harness, and still the same.. I must say I am a bit puzzled by this.
  1. Sharan nsf electric window problem
    By colinwdick in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2008, 11:51 PM
  2. sharan vr6 auto gearbox problem
    By sh4h99 in forum Touran - Sharan - Caravelle
    Last Post: 30-06-2008, 10:04 PM
  3. Sharan MPH display problem please help.
    By Trinityj in forum Touran - Sharan - Caravelle
    Last Post: 30-04-2008, 04:59 PM
  4. Sharan Exhaust recirculation problem
    By brauser rexel in forum Touran - Sharan - Caravelle
    Last Post: 30-01-2008, 09:57 AM
  5. Sharan Instrument Cluster Problem
    By stall1970 in forum Touran - Sharan - Caravelle
    Last Post: 24-01-2008, 05:54 PM
