Thread: VAG-Com Leads
  1. VAG-Com Leads
    Jun 2009
    Chelmsford England
    Hi i have a 98 A6 2.5 tdi and want to get vag-com so i can check if fault codes.
    Can anyone tell me what leads i need and where is the best place to get them?
    thanks
    Rob
  2. Re: VAG-Com Leads
    Jan 2008
    Mansfield, UK
    If you just want to scan, you can buy a generic OBD lead from ebay and use the shareware version of VAG COM.
    To clear fault codes, the best thing to buy is the proper USB HEX-CAN lead, that way your lead is futureproof and can do all cars from 95-present day.
    Last time I checked a company called Marshalls Industrial was the cheapest at around £235.
  3. Re: VAG-Com Leads
    Aug 2008
    check these links out
    http://www.ross-tech.com/vag-com/car...ons/100a6.html
    so your car is a c5/4b so you qill need one of the cables listed in the middle columb
    heres a list of where you can get a cable from also direct from ross tech
    http://www.gendan.co.uk/
    http://www.onboarddiagnostics.co.uk/
    http://www.mi-uk.com/
    http://www.v-techuk.com/
    hope this helps paul
    dont bother with cables from ebay
    gendan do a cheap cable and will give you back up if you need it
    i saw a old cable on ebay that supposed to do every car but it wont and they wanted £60 what a rip off
    Last edited by saabsalltheway!; 11-07-2009 at 10:53 AM. Reason: some one suggested using a cable off ebay
  4. Re: VAG-Com Leads
    Jun 2009
    Chelmsford England
    Quote Originally Posted by shark_90 View Post
    why can you not clear fault codes with a ebay lead?
    excuse my ignorance this is new to me.
  5. Re: VAG-Com Leads
    Canada
    Quote Originally Posted by TDI-Rob View Post
    the ebay lead will clear fault codes, but it won't allow chnages unless you register the shareware software.
    As for proper cables they are so much better and the shareware software is really old and limited now
    VW Tiguan 4motion 2.0T 2015 - Awesome snow churning 4x4 GTI 😉
  6. Re: VAG-Com Leads
    Jun 2009
    Chelmsford England
    Quote Originally Posted by onzarob View Post
    So a registered version of Vag-com is needed to make changes, but the leads don't matter?
    what is the differance between a ebay lead and a expensive lead?
  7. Re: VAG-Com Leads
    Canada
    what is the difference between a ebay lead and a expensive lead?
    the ebay lead (3rd party) has to be registered, to do adaptations and other functions. the registration is tied to one computer only.
    The Ross-tech leads hold the license so you can use any oc with the software installed. you just need to plug the lead in.
    look here for more info
    http://www.ross-tech.com/vag-com/download/archives.html
  1. A4 2.8 plug leads
    By ajsphead in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2013, 05:52 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Golf GTi Ignition Leads
    By Luce in forum Golf MK3 - 1993 - 1999
    Last Post: 03-01-2008, 03:43 PM
  4. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
