Thread: Replacing rear pads with electronic handbrake
  1. Replacing rear pads with electronic handbrake
    Jul 2009
    warwick
    Hi I own a 55reg passat and I need to change the rear pads but wasnt sure if I have to do anything different to get the piston back. I have changed rear pads on cars before where you have a tool to turn and push the piston back at the same time. Do I do anything different with it being electronic. Thanks
  2. Re: Replacing rear pads with electronic handbrake
    Redditch
    Yarp- you need vag-com to wind the piston back in. (or dealer/garage to do it with their programs)
  3. Re: Replacing rear pads with electronic handbrake
    toneil461 Guest
    Yes, you need to wind back the handbrake motors affixed to the rear calipers. You'll need an electronic programmer/coder reader type to do this task that plugs into the diagnostic socket. Not really a DIY job unless you want to invest in the equipment. You also use the same equipment to reset the motors once you have fitted the new pads.
    Terry..
  4. Re: Replacing rear pads with electronic handbrake
    Nov 2008
    Lincoln, UK
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  5. Re: Replacing rear pads with electronic handbrake
    epsom,surrey
    laserline do the tool you need. i bought one .it does the passat and the a6. cost around £130.
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  3. How does the Quattro system work?
  4. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
