Re: cigarette lighter –
04-07-2009,08:55 PM
Originally Posted by
benjie
Ditto, especially if you want to charge a sat nav on the dashboard - then it's a lotto as to which control the wire gets in the way of!
Before I installed my RNS-E the cig lighter was a pain!
However, to overcome this I installed two 12v cig power sockets just behind the dashboard above the fuse box behind the the drivers side access panel when the door is open. They powered my Snooper and TomTom without all those wires everywhere. Parts were a couple of quid from Maplin.
I added a fuse in the fusebox to feed these sockets independently - this feed is only powered when the ignition is on.
The Snooper is still in place, removed the 2nd socket once I went over to an RNS-E unit.
A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
