Thread: 1.9TDI hot starting problem
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
  1. 1.9TDI hot starting problem
    Jul 2009
    Dublin Ireland
    Hope someone can help me. Have a 04 A3 1.9Tdi, with 80K miles. Car always starts perfectly from cold, but not when warm or hot.
    If I'm on a journey and stop to refuel or take a toilet break - i.e. 10 mins or so, the car will not re-start without a lot of effort. If I pump the throttle it eventually re-starts after a 2-3 mins of coaxing.
    Otherwise the car is running fine and the mpg, etc is good.
    Any ideas or should I just get a diagnostic check done?
    Thanks.
  2. Re: 1.9TDI hot starting problem
    May 2009
    Belfast
    Have you checked the glowplugs?
    Failing that, it sounds like the problem my 1.9 is experiencing, starts fine (but maybe a tad too violently) in the morning, but short jump into the shop for 5 mins would lead to a 3 second turnover before it'll start - and even then it judders into life.
    Are you experiencing any vibrations/rattles when idle? Does the car feel any different to recently?
  3. Re: 1.9TDI hot starting problem
    Jul 2009
    Dublin Ireland
    No. The car is running as normal and it takes me more than 3 secs to re-start - more like 3 mins. It only happens when the engine has been running for a while and is fully hot. Starting from cold is perfect, no more vibrations or rattles from idle than usual!
  4. Re: 1.9TDI hot starting problem
    Jul 2009
    Dublin Ireland
    I'm guessing it's a problem with some sensor on the engine, or something to do with the air/fuel mixture.
  5. Re: 1.9TDI hot starting problem
    May 2009
    Belfast
    No probs. Im gonna leave my car in in a few weeks to have it looked at - but it doesnt sound as bad as yours!
    Good luck - keep me posted if you get to the root of the prob.
  6. Re: 1.9TDI hot starting problem
    Jul 2009
    Dublin Ireland
    Well i generally drive from A to B and stop, so it's not really a problem 80% of the time. If I'm on a journey and stop for 5 mins or to refuel then it plays up, but only when the engine is fully hot.
  7. Re: 1.9TDI hot starting problem
    Feb 2009
    I had the same problem on 1.9tdi Golf ie:
    - Starts and runs perfectly from cold
    - Restarts ok if just turned off for a few moments
    - But if left say 15/20mins from hot can't restart
    Not a proper fix, but you can get around this by unplugging the connector to the engine temperature sensor (rear side of cylinder block on the right).
    You can now start and then plug the connector back in.
    My local vdub dealer couldn't fix it properly so offered a car swap or cash back.
    Shiny (sometimes) Golf V GT TDi140
    Shameless plug: http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
  8. Re: 1.9TDI hot starting problem
    Jul 2009
    Manchester
    I would say the coolant temp sensor
    Very common fault
    The engine will be warm , but then it will be thinking it is cold , and then can over fuel
    059 919 501A is the part number for the superceeded one , now green instead of black
    Get a seal to go with it
    Approx £23 ish + VAT for them
    Approx 15 mins to replace
    Just do it when the engine is cold too
    Sarah
  9. Re: 1.9TDI hot starting problem
    Jul 2009
    Dublin Ireland
    Thanks for this information Sarah - makes perfect sense!
    Where in the engine bay is this sensor located?
  10. Re: 1.9TDI hot starting problem
    Aug 2011
    Scotland
    It looks like there are at least two different types of hot start issues:
    1. From hot the car does not start and takes while to restart if at all.
    2. From hot the car restarts every time but after some brief violent thud/judders.
    I have been suffering from point 2 above (explained below) on an A3 (2007) 1.9 tdi.
    1. Cold start no problems all sounds fine, idle fine.
    2. Hot start horrible violent judder/thuds for 1-2 seconds then engine starts - feels like the engine is about fall out of the engine bay but it has never failed to start from hot and idle seems fine afterwards.
    I have been trying to narrow down the time gap when the problem is at its worst. Once the engine has started to cool down anywhere between 90-70 on the temp gauge the restart is likely to be poor but when engine temp cools to below 70-50 on the gauge the start gets back to normal, having said that I have had the car start poorly in lower temp range.
    Other points worth noting:
    The Clutch, flywheel and pressure plate were all recently replaced.
    Explaned problem to Audi dealer, they got the car in for diagnostics, however they tell me no error codes and they could not replicate the problem
    any update on your problem or advice appreciated.
  1. A4 1.9TDi acceleration problem
    By TimS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-07-2012, 08:13 PM
  2. Intermittent Starting Problem - TDI 115
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 07-05-2009, 01:27 PM
  3. Golf TDI MK4 hot starting problem
    By scotty15 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-12-2007, 04:48 PM
  4. Starting Problem - Polo X 2000 1.4 SE
    By mclean1979 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-10-2007, 11:46 AM
  5. 2000 Golf 1.8t Hot starting problem ANY IDEAS
    By cricketblue in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-07-2007, 11:53 AM
