Thread: 1.9TDI hot starting problem
Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
  1. Re: 1.9TDI hot starting problem
    #41
    Jun 2008
    L'Etang La Ville, France
    Many thanks ibizagreg. I took it to my local garage this morning and he said something was wrong between engine and gearbox and suggested I take it to Audi. I mentioned the DMF but he said it was automatic and didn't have a DMF but a torque converter. The starter motor sound more likely as the car drives perfectly and I only get the issue when engine is hot.
  2. Re: 1.9TDI hot starting problem
    #42
    Aug 2016
    Estonia
    There is now a way to solve starting problem:
    Wiring kit for warm engine start problem elimination (for 2-pin sensor) | eBay
    Write now there is wiring kit only for this temperature sensor but we are working on to make kits for older and newer sensors versions.
  3. Re: 1.9TDI hot starting problem
    #43
    Apr 2014
    Birmingham UK
    Quote Originally Posted by armStart View Post
    Anyone tried this?
  4. Re: 1.9TDI hot starting problem
    #44
    Jul 2007
    glasgow
    35 Post(s)
    I would guess that it tells the ECU its colder than what it actually is,giving extra fuel in a default setting
  5. Re: 1.9TDI hot starting problem
    #45
    Aug 2016
    Estonia
    This kit is telling to the ECU it is cold only when you are starting the car.
    It does not affect engine normal working.
  6. Re: 1.9TDI hot starting problem
    #46
    Feb 2017
    Northern Ireland
    My advice is to start with getting the battery replaced. I had this annoying problem for years, even happened when getting the car MOT'd and it doesn't look good. After my battery went flat I replaced it, and the hot start problem has disappeared. I looked at lots of car forums when trying to investigate the problem and never got a clear answer.... this was my clear answer. I'm going to post this advice to as many forums as possible now to let people know.
  7. Re: 1.9TDI hot starting problem
    #47
    Apr 2014
    Birmingham UK
    Quote Originally Posted by peetza View Post
    Bang on mate, a new battery fixed my hot starting issue. It's been probably 6 months since I changed it and the problem has dissapeared. Thank God for that! So yes like Peetza has said above - get the battery changed and hopefully that should cure the problem.
  1. A4 1.9TDi acceleration problem
    By TimS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-07-2012, 08:13 PM
  2. Intermittent Starting Problem - TDI 115
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 07-05-2009, 01:27 PM
  3. Golf TDI MK4 hot starting problem
    By scotty15 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-12-2007, 04:48 PM
  4. Starting Problem - Polo X 2000 1.4 SE
    By mclean1979 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-10-2007, 11:46 AM
  5. 2000 Golf 1.8t Hot starting problem ANY IDEAS
    By cricketblue in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 29-07-2007, 11:53 AM
