Thread: Lost Central Locking / Electric mirrors & Electric Windows on 2 Passats
  1. Unhappy Lost Central Locking / Electric mirrors & Electric Windows on 2 Passats
    Jul 2007
    Rochdale UK
    I was changing a window regulator over from my Mums passat that is soon to be scrapped into my passat.
    Tried and tested the windows etc while doing the work all operating fine put it all back together and now in both cars the central locking from the key fob won't close the drivers door other 3 doors close, the window switches on the drivers door are all dead and the electric mirror switch is dead.
    Their is power to the door lights illuminate, central locking switch on drivers door closes the drivers door only.
    Exact same fault on both cars which is really weird i have checked all the electrical connections, they are all good and I don't think their is any you can get in the wrong way around.
    Fuel cap button works.
    Please help i only have until sunday to fix my mums car before she needs to drive home 250 miles and i wont get another chance for ages.
    Cheers Ben.
  2. Re: Lost Central Locking / Electric mirrors & Electric Windows on 2 Passats
    Norfolk
    If you swapped the control units with the window regulator the ccm will not Know the coding of the exchange unit and so won't work. Try a vag-com code read to see if it reports an error. Oh for the days when you could just swap bits from car to car.
  3. Re: Lost Central Locking / Electric mirrors & Electric Windows on 2 Passats
    Jul 2007
    Rochdale UK
    I did swap the door control module over at one point but they are know using the original ones with just the window regulator swapped.
    Is their any way to reset it without VAG-Com is it going to cost a lot to get a garage to reset the code or is it a simple job.
    Cheers Ben.
  4. Re: Lost Central Locking / Electric mirrors & Electric Windows on 2 Passats
    Norfolk
    You can't tell if a fault has occured without a code read. Try the vag-com section to see if anyone near you can check it. It shouldn't cost more than half hour labour at any garage that has the equipment.
  5. Re: Lost Central Locking / Electric mirrors & Electric Windows on 2 Passats
    Jul 2009
    sheffield uk
    had this when i got my passat..... tried everything but wasnt until i checked the wiring to the comfort control module (under passanger footwell carpet) that i found that ALL wires had melted together . it was a mirical that car didnt go up in flames . every thing else sworked car ran fine but just lost all power to windows and locking....
    hope this helps.
  6. Re: Lost Central Locking / Electric mirrors & Electric Windows on 2 Passats
    Sep 2009
    oxford UK
    I have beenhaving a similar problem on a T reg passat ewstate with the front windows failing to work. After cleaning all the fuses and various bits of titivation with little success, I disconnected the battery, counted to ten and the then reconnected it. Voila, Working front windows"!. Wouldn't help the melted wire syndrome of course, but it cured this annoying intermittent failure so far.
    Old-Robin
  1. Lupo Central Locking and Electric windows
    By Neil_How in forum Polo - Derby - Lupo - Fox
    Last Post: 26-04-2021, 04:37 PM
  2. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  3. Please Help Problems with Electric Windows, Central locking, etc
    By Bodferret in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-12-2010, 11:00 AM
  4. Central Locking and Electric Window Fault
    By Joe_Kobrin in forum Touran - Sharan - Caravelle
    Last Post: 09-12-2009, 09:40 PM
  5. Replies: 3
    Last Post: 07-02-2008, 09:34 PM
