Thread: Engine Oil Pressure light, No engine fault codes on VAG COM
  1. Engine Oil Pressure light, No engine fault codes on VAG COM
    Mar 2009
    Hello all,
    I have an Audi A3 1.8T 1999. The car has recently had an oil and filter change, about 3 months back. Just during the last couple of weeks, the "Engine oil pressure" light has been coming on after driving for about 20 mins of steady driving, accompanied by a beep. And it keeps going off after that.
    I did an auto scan using the VAG CoM, but found no fault codes on the engine. I even did an engine oil change along with a oil filter change (with engine flush). But the problem persists.
    Could it be an oil pump problem? Is there a way of knowing for sure, using VAG COM, where the problem lies? I am new to this tool.
    Any help would be much appreciated.
    Here's what my VAG COM scan came up with.
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01: Engine
    Controller: 06A 906 018 AQ
    Component: 1.8L R4/5VT MOTR HS D04
    Coding: 04000
    Shop #: WSC 06313
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 1J0 907 379 H
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 13504
    Shop #: WSC 06435
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    16-10 - Signal Outside Specifications - Intermittent
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 8L0 919 930 H
    Component: AB-KOMBIINSTR. VDO D15
    Coding: 04442
    Shop #: WSC 00000
    IMMO-IDENTNR: AUZ7Z0X0911407
    Address 35: Centr. Locks
    Controller: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 13130
    Shop #: WSC 06313
    12 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    77-00 - Internal Supply Voltage
    49-00 - No Communications
    Address 45: Inter. Monitor
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 06313
    Address 56: Radio
    Controller: 4B0 035 186
    Component: Radio 0001
    Coding: 00205
    Shop #: WSC 06313
    3 Faults Found:
    00852 - Loudspeaker(s): Front
    36-10 - Open Circuit - Intermittent
    00854 - Radio Display Output in dash Panel insert
    49-10 - No Communications - Intermittent
    65535 - Internal Control Module Memory Error
    00-00 - -
    End --------------------------------------------------------------------------------------------------
  2. Re: Engine Oil Pressure light, No engine fault codes on VAG COM
    Jun 2009
    surrey
    I would have someone do an oil pressure check on her, its an easy enough job, it could well be a dodgy oil pressure switch?
    ive not heard of oil pumps going on these engines before.....but theres always a first
    Regards
    Rob
  3. Re: Engine Oil Pressure light, No engine fault codes on VAG COM
    RedZed2009 Guest
    dfilogik.... I have posted a similar problem, but mine was only at start up... what was the outcome of your issue?
  4. Re: Engine Oil Pressure light, No engine fault codes on VAG COM
    Jun 2010
    Banbury England
    Hey I have seen this fault on a lot of these engines and it's very worth while checking that the oil pump pick up is not blocked especially if the oil sump has previously been off usually to much sealant is used and that blocks the strainer
  1. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  2. Answers from an oil expert...
    By oilman in forum Archive posts
    Last Post: 20-01-2008, 05:30 PM
  3. Does your oil light go out before engine start?
    By Alas in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2007, 10:04 PM
  4. Replies: 1
    Last Post: 25-03-2007, 11:03 PM
