Thread: Launch Control
Results 1 to 10 of 12
  1. Launch Control
    Apr 2009
    I seen mention of this in a couple of threads - is it just a case of building the engine rev's with the foot on the brake, or is it something special and if so do all dsg boxes have it?
  2. Re: Launch Control
    Apr 2009
    Not all DSG boxes allow launch control, no. I believe it's only the pokier engines i.e. GT, GTD, GTi.
    Google confirms:
    - sport mode OR 1st gear with tiptronic
    - disable ESP
    - left foot on break
    - right foot on throttle (it won't rev above 4k)
    - release brake, travel back/ forward in time once 1.21 gigawatts is achieved
  3. Re: Launch Control
    Aug 2008
    Quote Originally Posted by Robbie G View Post
    For what it is worth my dealer told me (after I had the car 3 months) it is not on the 7 speed boxes - I know it is not on my 1.4 TSI 7speed DSG.
  4. Re: Launch Control
    Apr 2009
    Charles
    So did he say which engines did have this mystical device?
  5. Re: Launch Control
    Aug 2008
    Quote Originally Posted by JCClem View Post
    It was more the 7 Speed box does not have it - no mention of engines.
  6. Re: Launch Control
    North Shields, UK
    The 7 speed DSG can't handle as much torque going through it at the 6 speed one can, hence you don't get the 7 speed DSG with the Torquey TDIs and the 2.0TSI engine (and above, as the range may increase).
    1.4TSI (160PS) and below petrol engines will have the 7 speed dry clutch DSG.
    Launch control would fry the clutches on the 7 speed DSG. Sitting at lights holding 4000rpm for the launch control (until the lights change) will make you look a bit of a *** anyway.
  7. Re: Launch Control
    Apr 2009
    Well I'm slightly disappointed to find that my new car (160 TSi) will not have launch control, but on the other hand I can't see me using it all that often to say the least.
    What are the advantages of a dry clutch DSG system compared to the wet clutch 6 speed? Why not just create a wet 7 speed?
  8. Re: Launch Control
    North Shields, UK
    7 speed dry clutch has less resistance to movement and so gets better economy, not only from the extra cog, but as it takes less effort to drive the gearbox than the 6 speed that has an oil submerged clutch.
    That oil bath on the 6 speed does offer a lot more protection for the clutch and makes it a lot more resilient, hence its use on the torquier engines.
    A wet 7 speed clutch will probably end up having negligible economy gains over the 6 speed, rendering it pointless.
  9. Re: Launch Control
    Apr 2009
    Maisbitt
    Thanks for the info; is this why the power is 10bhp down on the old GT?
    Also does this mean the engine management should not be tinkered with as the DSG cannot handle more power?
  10. Re: Launch Control
    Chester-le-Street, United Kingdom
    Maisbitt
    i bet that's not been thought of before
    good point.
    i predict---
    worms,-can of.
    regards,
    stewy
    first time i was up a ladder i was down a well
    4th cog,--two to go
  1. Please Help Battery + Climate Control Unit + Engine + What's next?
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2009, 07:39 PM
  2. dsg launch control
    By baldwalker in forum Golf MK6 - 2009 - 2013
    Last Post: 02-05-2009, 11:07 AM
  3. Coding of engine : witout cruise control
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2009, 08:19 PM
  4. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
