Thread: Healp needed VAG com
  1. Healp needed VAG com
    Jun 2009
    norway
    Yellow steering wheel lamp is on, and ESP lamp is on after upgrade to MFSW.
    here is the vag com code, but section 44 steering assist does not work.
    Any workaround?
    Thursday,14,May,2009,15:12:19:02696
    VCDS Version: Release 805.4
    Data version: 20090602
    bildiagnose.no
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 77 7D
    VIN: WVWZZZ3CZ7E050897 Mileage: 72990km/45353miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 021 NK HW: 03G 906 021 AB
    Component: R4 2,0L EDC G000SG 9354
    Revision: --H05--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 05311 000 00000
    2 Faults Found:
    005784 - Please Check DTC Memory of Steering Wheel Electronics
    P1698 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 6
    Fault Frequency: 2
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00001100
    Bin. Bits: 11000000
    (no units): 0.0
    005703 - Check Coding of ECUs on Powertrain Data Bus
    P1647 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 2
    Mileage: 72949 km
    Time Indication: 0
    Date: 2009.06.13
    Time: 00:00:01
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00001100
    Torque: 0.0 Nm
    Torque: 351.4 Nm
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
    Component: ESP 440 C2 H015 0004
    Revision: H015 Serial number: 0667711255
    Coding: 0013602
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
    Component: ClimatronicPQ46 050 0505
    Revision: 00050005 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    No fault code found.
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000005955816
    Coding: E1888F0700041A00000A00000F00000000095D435C0000
    Part No: 3C1 955 119 A
    Component: Wischer VW461 012 0503
    Coding: 00063445
    Shop #: WSC 05311
    Part No: 1K0 955 559 AE
    Component: RLS 140706 014 1201
    Coding: 00208933
    Shop #: WSC 05311
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
    Component: 03 AIRBAG VW8 030 2522
    Revision: 10030000 Serial number: 003B1PEK57WW
    Coding: 0012339
    Address 16: Steering wheel Labels: 3C0-953-549.lbl
    Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
    Component: J0527 0015
    Revision: 00005000 Serial number: 3C9953507P
    Coding: 0002314
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    4 Faults Found:
    00895 - Cruise Control Switch (E45)
    014 - Defective - Intermittent
    01044 - Control Module Incorrectly Coded
    00002 - Transmission Control Unit
    004 - No Signal/Communication
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 871 HW: 3C0 920 871
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: X0006000 Serial number: 00000000000000
    Coding: 0007105
    Shop #: WSC 67083 141 86212
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C067070899
    Coding: 3D3D2C44C62002
    Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
    Part No SW: 3C0 959 433 M HW: 3C0 959 433 M
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    Part No: 3C0 905 861 F
    Component: ELV 026 0380
    3C0905861F ELV 026 0380
    Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
    Part No: 1K0 919 887 F
    Component: Navigation 0028
    Coding: 0000101
    Shop #: WSC 05314 000 00000
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1123
    Revision: 12006001 Serial number: 00000509168717
    Coding: 0000053
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.134 H07 1806
    Shop #: WSC 02069 000 90108
    2 Faults Found:
    02546 - Steering Limit Stop
    Freeze Frame:
    Mileage: 72990 km
    Temperature: 30.0°C
    Voltage: 12.20 V
    Voltage: 12.00 V
    Freeze Frame:
    Address 46: Central Conv. Labels: 3C0-959-433-46.lbl
    Component: KSG PQ46 ELV 042 0472
    Coding: 0091020851030E763004941570084B0E703C00
    Part No: 1K0 951 605 B
    Component: LIN BACKUP HORN H07 7001
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1123
    Revision: 12006001 Serial number: 00000515968719
    Coding: 0000052
    Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000011
    Address 56: Radio Labels: 1K0-035-095.lbl
    Part No: 1K0 035 095 G
    Component: Radio 0028
    Coding: 0042400
    Address 77: Telephone Labels: 3C0-035-729.lbl
    Part No SW: 3C0 035 729 E HW: 3C0 035 729 E
    Component: Telefon 6009
    Revision: 00009000 Serial number: 0000000766479
    Coding: 0016043
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
  2. Re: Healp needed VAG com
    Jan 2009
    you mean you cant access the module?
    It looks like you need to put the steering assist into basic settings mode to reinitialize.
    Clear all the DTC's
    Ensure the coding for a MFSW is correct on the steering wheel electrics module
    Place steering assist into basic settings
    You may get additional help here : http://www.ross-tech.com/vag-com/car...ringangle.html
  3. Re: Healp needed VAG com
    Jun 2009
    norway
    Quote Originally Posted by quattrogmbh View Post
    Clear all the DTC's
    Once I try to Clear all the DTC's, they come back emidiatly.
    Ensure the coding for a MFSW is correct on the steering wheel electrics module, well this one is a little bit strange since I have a manual transmission, and the codes in vag com do not match 100%. It looks like it is coded correctly though.
    Here is the prioblem: I can not access group 060 on this module.
    [Select]
    [03 - ABS Brakes]
    [Login - 11]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 060
    [Go!]
  1. Vag com user in devon needed
    By ghee60 in forum VCDS - General Questions
    Last Post: 15-11-2010, 09:22 PM
  2. n296 BOOST CONTROL VAG MECHANIC NEEDED
    By quattroboy1986 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 10-05-2009, 06:18 PM
  3. Urgent Help Needed Please! VAG COM Owner In Essex?
    By mjom89 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-05-2009, 09:31 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
