Thread: Charging problem
  1. Charging problem
    Nov 2006
    derbyshire
    Hey, mk4 golf gt tdi 110, not charging on tickover but ok when reved. Is it possible to buy/get hold of the brush pack for the alternetor or is it a new alternator job, (AHF engine).
  2. Re: Charging problem
    In general you can buy brushes for most alternators,although,they are not supplied as spare parts from VW,but the voltage regulator is,and the brushes come with the regulator,depending on the make of the alternator.You would need to remove the regulator,to see the condition of the rotor.If the rotor is badly worn,you will be looking for a new alternator
  1. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  2. Power problem turbo not working
    By marfitzd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2008, 11:04 AM
  3. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  4. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
