Thread: Lambda sensor
  1. Lambda sensor
    Hastings, Great Britain
    Hi guys,
    Just want to know how easy is it to change a lambda sensor.
    Skinnyseand
  2. Re: Lambda sensor
    Nov 2008
    you can do it yourself but they can be a bit hard to get at. i have only took one out of a passat in the scrap yard. the actual sensor was easy to get at- although the air filter, i think was removed from the car. the hardest bit was getting the wiring disconnected and fed through the clips. i am sure someone will be along soon to give better advice
    Volkswagen Passat Sport 2.0 115bhp
  3. Re: Lambda sensor
    Thanks Chrisop. I am now trying to find where the wires lead to so I can unplug it.
    Skinnyseand
  4. Re: Lambda sensor
    Norfolk
    The lambda wires should lead to a four pin black plug which you disconnect. You should be able to read lambda values through vag-com but I'm not sure if all versions can. Ross-tech site may tell you which measuring blocks. If you send me an e-mail address I may be able to send some info. Goodluck
  5. Re: Lambda sensor
    I read the values. They usually start off at around 21.2% then it rapidly goes to 0.0% then it starts juddering and losing power.
    Skinnyseand
  6. Re: Lambda sensor
    Norfolk
    Sounds like you need a new lambda sensor. If you can scope it you will see the voltage oscilating up and down like a switch going on and off. It must clear a high point and a low point on each cycle and manage a fixed number of cycles per minute.
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
