Thread: transporter 2.5tdi 2003 glow plug light not staying on?
Results 1 to 8 of 8
  1. transporter 2.5tdi 2003 glow plug light not staying on?
    May 2009
    nottingham
    I have a 2003 transporter t4 2.5tdi. When you turn the ignition on the glow plug light comes on then goes off after about 1-2 seconds.
    If you try to start it then it won't start.
    I have tested the glow plugs and the relay they are ok.
    I have also had the test light to the glow plug wires and when the ignition is on there is power to the glow plugs for a good 10 seconds.
    If you put ignition on and wait till you here the relay click off after about 10 seconds the van will start as normal.
    Can anyone tell me how to make the glow plug light stay on for the correct time or what is causing this as the lady who owns it keeps trying to start it as soon as the light goes out. Grrrrrrrr!
    Thanks Paul
  2. Re: transporter 2.5tdi 2003 glow plug light not staying on?
    The fact that the control light goes out after a few seconds is normal.In what way did you check the glow plugs.
  3. Re: transporter 2.5tdi 2003 glow plug light not staying on?
    May 2009
    nottingham
    I have a glow plug tester tool that measures them in the vehicle induvidually. All 5 were working ok?
  4. Re: transporter 2.5tdi 2003 glow plug light not staying on?
    If you are 100% sure the plugs are ok,then i think the pump timing is out,these engines start almost as soon as they are turned over.
  5. Re: transporter 2.5tdi 2003 glow plug light not staying on?
    May 2009
    nottingham
    Thanks, I cant' see how the pump timing can be out non of that has been touched and as i said it starts perfectly if you wait until the glowplug relay clicks off after about 10 seconds.
    The problem is the awkward customer that wants the van to start the second the glow plug light goes out if it was mine i wouldn't even bother.
    Regards Paul
  6. Re: transporter 2.5tdi 2003 glow plug light not staying on?
    If you have diagnostic equipment it is easy to find out if the timing is out.
  7. Re: transporter 2.5tdi 2003 glow plug light not staying on?
    May 2009
    nottingham
    I have a mac scan and there are no trouble codes at all
  8. Re: transporter 2.5tdi 2003 glow plug light not staying on?
    It is not the fact of a fault being logged,it is to certify the timing is right,
  1. glow plug light flashing
    By rollingroadtune in forum Alhambra
    Last Post: 12-05-2009, 03:25 PM
  2. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
  3. glow plug light
    By smiglyy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-02-2008, 03:00 PM
  4. Where are the glow plugs?
    By Black Angus in forum The Commercial Range
    Last Post: 13-01-2008, 05:01 PM
  5. Glow Plug warning light flashing problem
    By Mark Hunt in forum Audi A4 - Archive Topics
    Last Post: 23-09-2007, 07:31 PM
