Thread: 2002 Golf TDi Central Locking problem
  1. 2002 Golf TDi Central Locking problem
    Good day gents & ladies, I wonder if any of you could shed some light on a problem we're enduring with my wife's Golf.
    Problem being the remote central locking key fob - one minute it works fine then 10 minutes later when you come back to the car the remote unlocking doesn't work. You have to unlock the drivers door manually and turn on the ignition before the alarm sounds then open all the remaining doors!!
    This is purely random as it can go for weeks not working right then all is fine for a few weeks then it goes again!!
    The locking part of the fob works fine, all the time, it's just the unlocking part that plays up which leads me to possibly think the fob or receiver may be at fault (a dry joint or something along those lines) as it was more suspect in the hot weather, but over the past week or two (while it's been very warm) it's worked fine
    I'm banging my head against a brick wall here, so I'm hoping some one here could give me a suggestion on where to go from here - disconnecting the battery and resetting the system has been mentioned on other threads so I was thinking of trying that next.
    Any advice will be greatly appreciated
    Thanks in advance
    Stu
  2. Re: 2002 Golf TDi Central Locking problem
    It's a simple suggestion, but have you tried renewing the fob battery?
  3. Re: 2002 Golf TDi Central Locking problem
    Quote Originally Posted by Eshrules View Post
    Thanks for the suggestion but that was the first thing I tried - I should have stated that above but forgot
  4. Re: 2002 Golf TDi Central Locking problem
    To be honest your issue sound very similar to a problem i had with my central locking a few weeks ago.
    It sounds like the micro switch is on its way out either on the drivers door or passengers hopefully not both.
    The best port of call would be to get a diagnostic check as i did and progress from there.
    I paid £25 for the diagnostic check at my local vw audi specilist worth every penny. Saves the messing about.
    Unfortunately the mirco switches are £90.00 plus vat though
    Good luck.
  1. Audi 80 Central Locking Problem
    By tp5harp in forum 80 - 90
    Last Post: 20-05-2010, 09:30 PM
  2. VW GOLF GT TDi - Problem!!
    By Ranger Bob in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2007, 09:49 PM
  3. Bizarre Central Locking problem
    By swiss_steve in forum Beetle 2000-
    Last Post: 14-03-2007, 09:21 PM
  4. Central Locking problem on a VW MK4 Golf
    By Shaz13230 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2007, 04:54 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
