Thread: Aircon Problems
  1. Aircon Problems
    Jun 2009
    Killucan Ireland
    I recently bought an 02 Golf 150 TDI and the aircon is not working properly.When the controller is on in Auto (not in ECON)Both underbonnet fans come on the compressor clutch engages but the air is still at ambient.The blower in the cabin works fine.I changed the pollen filter which was very dirty.I had the system leak checked and regassed.The coolant was quite low but the system showed no leaks and holds pressure.I mesured the voltage to the compressor with the aircon on and it shows 8.9v. Any Ideas.Thanks
  2. Re: Aircon Problems
    Jun 2009
    Manchester, England
    was there any improvement after you had it regassed
  3. Re: Aircon Problems
    Jun 2009
    Killucan Ireland
    No I'm afraid not.I am taking it back to the garage that did it to check that everything is still ok with the coolant side on Wednesday.Seems strange that the pressure was good and the report shows no leaks,The fans are running and the compressor clutch is engaging.Unless the compressor is bad.Just need to know if there are any checks I can carry out.
  4. Re: Aircon Problems
    Jun 2009
    Killucan Ireland
    Thanks for your continuing support.I went to the VW dealer and they pulled the fault codes.Quite an interesting fix.Still I guess no on is interested until it happens to them.No you can't have a kidney..........
  5. Re: Aircon Problems
    Apr 2007
    Sawtry, Cambs
    Moved to VCDS forum
  1. Please Help newbie needs help with aircon pump clutch???
    By b9g in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-08-2009, 10:04 PM
  2. Engine curring out on the motorway & other problems - please help!
    By oshy1981 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2009, 06:38 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Passat Aircon not working
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-01-2008, 09:52 AM
  5. 2004 A3 2.0TDI - aircon problems
    By MHAD in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-07-2007, 01:59 PM
