Thread: Oil Pressure. Stop Engine
Page 2 of 18 FirstFirst 123412 ... LastLast
Results 11 to 20 of 171
  1. Re: Oil Pressure. Stop Engine
    1841 Post(s)
    You mean the oil pump and the whole assembly has to be replaced, balance shafts the lot-a very common problem. The balancer shaft module with oil pump and chain come to around £760 plus fitting.
  2. Re: Oil Pressure. Stop Engine
    Oct 2005
    Am I right in thinking that these oil pump issues generally happen at about the 90k mark?
    I`m just coming up to 80k, and after 3 new injectors and possibly a new DMF (goes in tomorrow), I dont want to be faced with another huge bill that the almighty warranty company may or may not pay for.
    Seriously starting to think about getting rid of this car, which will be a shame as I really like the spec of it.
  3. Re: Oil Pressure. Stop Engine
    1841 Post(s)
    My neighbour’s car (thankfully for him still under the VW dealer warranty) failed at 50K and took the turbo with it as well.
  4. Re: Oil Pressure. Stop Engine
    Derry
    Quote Originally Posted by Spudrig View Post
    Stuart, the same thing happened to a neighbour in my street, and he has around 80k on his 2.0 TDi 140. I think he didn't have to get a new engine as he stopped immediately. It happened about 2 weeks ago and I saw him driving around a few days later, so I'm just assuming his car was ok. If I see him before I head off to the US, I'll let you know what his situation was.
    Quick update, I was just talking to my neighbour, and he told me that the failure of the oil pump took the turbo as well, just as Crasher said in the above post
    2006 B6 Passat 1.9TDi 105 | 35k | Deep Black Pearlescent | 18" OZ Superturismo Rims | Chrome Grill | 35% Tinted Rear Windows | Boot Lip Spoiler | Debadged
  5. Re: Oil Pressure. Stop Engine
    Thanks, Spudrig - Kind of wish I'd gotten the 1.9 now. Or something other than a VW!
    My neighbours Passat did the same thing, he shut the engine off immediately but it still destroyed the bottom end and the turbo but thankfully he was under an extended VAG warranty. When they are failing they deliver progressively lower oil pressure so that by the time the drive rod spins and loses all pressure bringing on the light, it is way to late. It is a shamefully bad design, not just poor manufacture.
    The only two preventative measures I can think of are to replace the oil pump/balancer assembly before it fails or to fit an oil pressure gauge so that you get an advanced warning, if you notice it. VAG products used to have a dual switch dynamic oil pressure warning system that went off if the oil pressure was below 1.8 bar (some were 1.4 bar) and I know countless engine this saved from serious damage. Now they depend on a 0.55 to 0.85 bar single switch system.
    Thanks, Crasher. Would you say that it's kind of inevitable on the 140 once it gets to high mileages (80-100k or more) or is it just a proportion of them that it happens on or a batch?
    I think I read on here previously that it was just a batch that was affected, but I can't stop worrying about this now, and don't really know what to do about it.
    I've still got £4k owing on the HP and when I bought the car I was hoping that it would sail past 100,000 miles and when the repayments were finished I would still have a car worth a few grand to sell or it would last for another few years after that.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  6. Re: Oil Pressure. Stop Engine
    1841 Post(s)
    That is difficult to say, I am not even convinced the replacement parts are going to be immune to the problem.
  7. Re: Oil Pressure. Stop Engine
    #17
    There is an ongoing campaign for the 2lt BKP engine,Service Campaign 13D8,although,not all vehicles are affected.Might be an idea to ask your dealer,if your vehicle is affected by this campaign.
  8. Re: Oil Pressure. Stop Engine
    #18
    Quote Originally Posted by kenney View Post
    Thanks - I've got a full VW history from the same dealer, and just had the timing belt and water pump replaced, so if the oil pump thingy goes belly up and wrecks the engine and they've known about the problem and said nothing then I'll be a bit annoyed, to say the least.
    But since the car is well out of warranty I don't suppose they owe me an legal obligation.
  9. Re: Oil Pressure. Stop Engine
    #19
    Derry
    Quote Originally Posted by Stuart W View Post
    I just wonder if a new oil pump would be a solution to this, just change it as a precaution?
  10. Re: Oil Pressure. Stop Engine
    #20
    Oct 2005
    I`d been thinking the same, but at over a grand as a precaution on a car that is fast depreciating....well you get my drift.
  1. 1997 A4 1.8T Sport - Power delivery and oil pressure
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2009, 06:22 PM
  2. oil pressure problem
    By silverado in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 27-04-2008, 05:05 PM
  3. Replies: 1
    Last Post: 25-03-2007, 11:03 PM
