Thread: Vw bora lack of power 1.9 tdi pd
  1. Vw bora lack of power 1.9 tdi pd
    Aug 2008
    hi all just done a scan of a bora 1.9pd
    any ideas would help with this
    Wednesday,03,June,2009,19:57:43:08836
    VCDS Version: Release 805.4
    Data version: 20090602
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    Address 01: Engine Labels: 038-906-019-ASZ.lbl
    Part No: 038 906 019 KJ
    Component: 1,9l R4 EDC G000SG 5256
    Coding: 00002
    Shop #: WSC 01266
    WVWZZZ1JZ4W056802 VWZ7Z0C7917330
    2 Faults Found:
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-00 - -
    17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
    P1144 - 35-00 - -
    Readiness: 0 2 0 0 0
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019970
    Shop #: WSC 01266 785 00200
    No fault code found.
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 A
    Component: 27 AIRBAG VW51 01 0008
    Coding: 12855
    Shop #: WSC 01266
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
    Part No: 1J0 907 487 B
    Component: Lenkradelektronik 0002
    Coding: 00008
    Shop #: WSC 01266
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J5 920 946 C
    Component: KOMBI+WEGFAHRSP VDO V20
    Coding: 17414
    Shop #: WSC 00000
    1 Fault Found:
    01336 - Data Bus for Comfort System
    80-10 - Single-Wire Operation - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01266
    1 Fault Found:
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 6G Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 01266
    Part No: 1C2959802A
    Component: 6G Tőrsteuer.FS KLO 0202
    Part No: 1C2959801A
    Component: 6G Tőrsteuer.BF KLO 0202
    Part No: 1C0959811A
    Component: 6G Tőrsteuer.HL KLO 0202
    Part No: 1C0959812A
    Component: 6G Tőrsteuer.HR KLO 0202
    Address 56: Radio Labels: 1J0-035-18x-56.lbl
    Part No: 1J0 035 186 D
    Component: Radio 0002
    Coding: 02403
    Shop #: WSC 01266
    fault codes have been cleared
    thanks paul
  2. Re: Vw bora lack of power 1.9 tdi pd
    Jul 2007
    Cheshire, or my A6
    We'll need to know if the codes come back.
    Also, was the MAF disconnected in the past which triggered the code?
  3. Re: Vw bora lack of power 1.9 tdi pd
    Aug 2008
    will be doing another scan soon
    car was serviced not too long ago but dont know if maf was disconected with ignition switched on
    will be looking at ross tech wiki too
    thanks paul
  1. A4 1.9 tdi in Limp Home mode after high power.
    By saidtheape in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2009, 01:10 PM
  2. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  3. 1.9 TDi help.....
    By Estoril Ben in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2007, 10:52 AM
  4. How does the Quattro system work?
  5. 1999 Golf 1.9 TDi Power Steering Fluid Low
    By gazza57 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 12:36 PM
