Hi, I have an A4 B5 (2000) and I need to get the panel that surrounds the centre console off.
I need to remove my head unit, but one of the clips holding it in is broken somehow and it can't be removed just by using the keys, so I want to get the surround off so I can see what's going on with the clip.
I've taken off the bit of trim around the cup holder/foglights and undone the two bolts there, I've undone the two bolts down by the seats, I've undone the bolt below the rear ashtray and I've also undone the two on the bracket infront of the gearstick (although that bracket is loose and I'm not sure it's secured to the panel.
Please help, or I'll never be able to remove the three other radio keys that are stuck in it, or install my aux line in.
Cheers,
Matt
