Thread: Do you need paint for alloy wheel repairs?
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Do you need paint for alloy wheel repairs?
    #11
    curiousgeorge Guest
    I got the Wurth paint and Halfords clear lacquer.
    The paint seemed to be a good match. I did a couple fo coats of that, then sanded the top coat down lightly before applying the lacquer (as recommended). However this made it lighter and it no longer matched. So I reapplied the paint and lacquered without sanding. I applied two coats of lacquer.
    It looks OK, but where the spray meets the old paint you can see the transition if you look closely.
    In hindsight I should have sprayed from further away and done it in the garage, because even a light breeze and the srpay goes everywhere.
    One strange thing - some lacquer had run onto the unsprayed part and when I tried to wipe it off with a rag it took off some of the existing paint underneath.
  2. Re: Do you need paint for alloy wheel repairs?
    #12
    Feb 2009
    Glasgow UK
    Hey George, I used the Wurth paint AND the Wurth lacquer. After a couple of coats of paint and a light sanding down I'm sure I painted another coat, left to dry and then used the Wurth lacquer ( again 2-3 coats )
    I did my refurb indoors as you'd never get a calm enough day otherwise and or foreign objects landing on it. I agree that you really have to try n blend it in, using even a little t cut or similar to remove any harshness. I found with a little work that mine was barely noticeable, even close up.
    On yours, if you have to look closely as you say, it must be a pretty good repair? The only way to overcome this would be to respray the whole wheel I guess. Are you satisfied with the match to the other wheels?
    How about some pics George?
    Jim
  3. Re: Do you need paint for alloy wheel repairs?
    #13
    curiousgeorge Guest
    Sure, here you go.
    It's hard to see from the photo but there is a slight difference in shade between the new and the old. And I didn't use filler so you can see where the scrape was at the edge of the rim.
    Still I think it's OK for a first DIY attempt. It's protected and not visible from a distance.
  4. Re: Do you need paint for alloy wheel repairs?
    #14
    Feb 2009
    Glasgow UK
    Hey George, as you say, looks pretty good for a first time DIY effort and about a 100% better than it was for sure.
    Considering it was done with the tyre in situ and no filler you must be pleased.
    Jim
  5. Re: Do you need paint for alloy wheel repairs?
    #15
    curiousgeorge Guest
    Cheers, and thanks for your help!
  6. Re: Do you need paint for alloy wheel repairs?
    #16
    Jun 2008
    How it going everyone,
    I have a set off genuine VW Indianapolis alloys on my Mk 5 Golf. Bought one of those alloy repair kits in Halfords but I dont trust the can of spray paint alloy paint that comes with it. Does anyone know the paint code for those Indianapolis alloys. Or would I get it in the service book. I know the Chassis paint code will be there but will the alloy one be there
  1. How To DIS AND CRUISE RETRO FIT b6+b7
    By a8 tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2014, 09:43 AM
  2. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  3. Wishbone Front / Rear Axle Bush which brand
    Last Post: 23-05-2009, 12:27 AM
  4. Crunch! Need help with wheel paint please...
    By GE90 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-04-2009, 06:16 PM
  5. How does the Quattro system work?
    By webchem in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 01-07-2007, 04:44 PM
