Thread: Water pump went, car now wont start
  1. Water pump went, car now wont start
    Dec 2007
    hi
    my water pump blew on 2002 a4 1.9tdi, got the pump replaced but she wont start, diagnostices have indicated cam belt sensor is damaged but i dont think that would prevent it starting...any thoughts anyone? p.s timing belt is ok
  2. Re: Water pump went, car now wont start
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi,Yes it would! ECU doesn`t know what cylinder is firing.
  3. Re: Water pump went, car now wont start
    1840 Post(s)
    I would say it is more likely just incorrect valve timing, even one tooth out and they will not start and any more than one tooth and they hit. How was the cam timing set?
  4. Re: Water pump went, car now wont start
    Dec 2007
    thanks fellas, mechanic tried drying out cam shaft sensor, but it keeps cutting out, he has ordered new one, which is coming this morning, he says it will cure problem. says previous mechanic should have changed water pump when putting new timing belt on. belt was changed last at 99k miles, car now has 130k on it, will let you know how it goes
  5. Re: Water pump went, car now wont start
    Dec 2007
    new cam sensor fixed the problem, however there is a droning noise coming through when i get to about 50 mph, could this be a bearing perhaps????
  6. Re: Water pump went, car now wont start
    Nov 2008
    20 Post(s)
    Pleased to here your sensor fixed it! Hope the noise isnt serious,one thing after another aint it!
  7. Re: Water pump went, car now wont start
    Dec 2007
    U R right, 320 quid for water pump and sensor and labour, could have been worse, just wonder what this other noise is
  1. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  2. Polo Cooling system
    By nigell in forum Polo - Derby - Lupo - Fox
    Last Post: 27-03-2008, 09:35 PM
  3. help needed urgently
    By ME! in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-01-2008, 04:40 PM
  4. In car noise in new Golf 1.6 FSI
    By mk4ever in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-11-2006, 10:43 PM
