Thread: air bubbles in fuel line
  1. air bubbles in fuel line
    May 2009
    Bristol, UK
    There are air bubbles in the clear fuel line running from the filter to the pump on my 1.9TDi. I serviced it today by removing the control valve, taking the unit out of its housing and drawing off some fuel from the plastic drain screw on the bottom.
    I put everything back together and started the engine and there were still a lot of air bubbles visible. I revved the engine a few times and they didn't go away.
    Checked the Haynes manual and he says there shouldn't be any bubbles but doesn't say what causes it or how to remedy it. The car seems to be running fine. Does anybody have any advice?
  2. Re: air bubbles in fuel line
    1840 Post(s)
    Quite normal, nothing to worry about.
  3. Re: air bubbles in fuel line
    May 2009
    Bristol, UK
    Good!
  1. Replies: 2
    Last Post: 24-11-2010, 11:35 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. passat bubbles in fuel line what can cause this
    By jill300268 in forum Early Passat Forum - Pre 97
    Last Post: 11-01-2008, 11:25 PM
  4. AUDI S LINE SPORTS RANGE RAISES ITS GAME
    Last Post: 01-12-2005, 08:52 PM
  5. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
