Thread: Battery draining
Results 1 to 9 of 9
  1. Battery draining
    May 2009
    Surbtion
    Please help!!!
    Something seems to be drawing a current from the battery draing it after a couple of days. The alternator seems to charge up the battery so not to sure if it could be a battery fault or not. How can I test the battery?
    Hope someone out there can assist as my wife is doing my head in
    cheers
  2. Re: Battery draining
    How old is the battery,?You can check the specific gravity,of the battery,this will give you an idea of the batterys condition.Or remove the plugs,and get someone to cranck the engine if you see any signs of the electrolyte,boiling,in any of the cells,the battery is defektive
  3. Re: Battery draining
    May 2009
    Surbtion
    Thank for the reply
    The battery is about 3 years old. Not to sure whether there are any plugs on the battery. It is a type of battery with a plastic window which states if it show green, the battery is in a good condition. I think the best way forward is probably to take the battery for a free check. I forgot to mention though, that all of this started after we had a cold snap with some snow.
    I also have another fault. Maybe you can help.
    The warning buzzer that sounds when ever you open the door with the head light on does not sound any more. Any ideas?
    thanks
  4. Re: Battery draining
    Okay your battery has a magic eye,what colour is the electrolyte.Regarding the buzzer,does the interior light function when you open and close the door?.Snow at this time of year,where is Surbtion?
  5. Re: Battery draining
    May 2009
    Surbtion
    The electrolyte is showing green. It says on the barry if it shows black, then the battery is defective. I will double check this again tonight as I am at work currently. With regards to the buzzer, the interior light does work when I open the door.
    Surbiton is about 1/2 hour ourside London. The snow was back in Feb and eversince this problem has been occuring
    regards
  6. Re: Battery draining
    Does it not work from any of the doors?
  7. Re: Battery draining
    Jun 2009
    cbba-bolivia
    Hi; regarding the light on warning noise, it might be that you accidently unplugged the relay looking thing, you can easily identify this in the fuse panel because it stands out completely from the rest also has a type of grill-like covering on the top part of it. It might be loose or you might even need to replace it if it's shorted-out. hope this helps..
  8. Re: Battery draining
    Mar 2009
    East Yorkshire
    Hi, check your rear windscreen, top right when looking from the back.
    Best time is early morning after a heavy dew or if it is frosty. If there is a clear oval shape with no dew or frost, then it is a problem with your radio, I had mine replaced under waranty.
  9. Re: Battery draining
    Mar 2008
    High Wycombe
    The best way to check the battery is to take it to Halfords, or your local car parts shop and ask them to test it for you. I know that Halfords do this for free, and there's no obligation to buy a new one if it is faulty.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Please Help Battery + Climate Control Unit + Engine + What's next?
    By bartyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2009, 07:39 PM
  2. Battery drains overnight
    By Jonse123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2008, 01:53 PM
  3. Problems with battery draining on a Passat
    By pegs in forum Passat - Archive Topics
    Last Post: 17-10-2007, 10:45 AM
  4. Polo draining battery
    By derbyaj in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2007, 04:02 PM
  5. Seriously annoying battery problem!
    By JPawson8 in forum Passat - Archive Topics
    Last Post: 08-10-2006, 02:45 PM
