Thread: couple of questions
  1. couple of questions
    May 2009
    norfolk
    Hi all
    I have just fitted a oil pressure gauge and wondered if any of you know what the oil pressure should be at tick over? on a 19tdi 130 highline,just want to make sure its all working ok, also now I have took the old sensor out it is beeping at me and telling me to stop, how can I stop this now I have done away with the sensor
  2. Re: couple of questions
    May 2009
    Chester
    you need the sensor in as well as th new gauge to stop the alarm.
  3. Re: couple of questions
    The oil pressure should be around 1bar on idle,engine warm.You need an adapter to fit the switch.But to check if the gauge is working,you can run the wire to the switch to earth.
  4. Re: couple of questions
    May 2009
    norfolk
    Quote Originally Posted by kenney View Post
    cool thanks people, My pressure is sitting at about 30psi so around 2 bar at tickover on a warm engine, I got a t joiner in the end and now have both connected. I was supprised how high the pressure is on a cold engine
  1. 2.0 TDi - couple of questions!!
    By elPaulio in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-05-2008, 01:56 PM
  2. Couple of questions on new Passat
    By sdrio in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-04-2008, 11:41 PM
  3. New kid with a couple of questions.........
    By leefrizz in forum Audi A3 - Archive Topics
    Last Post: 25-04-2008, 12:29 PM
  4. A couple of engine questions (110 tdi) and oil
    By tezray in forum Audi A3 - Archive Topics
    Last Post: 25-09-2007, 11:48 AM
  5. A3 - Couple of questions from new owner
    By enginious in forum Audi A3 - Archive Topics
    Last Post: 28-01-2007, 10:28 PM
