Thread: A6 MMI 3G radio/TP/TMC problem
Page 1 of 27 12311 ... LastLast
Results 1 to 10 of 269
  1. A6 MMI 3G radio/TP/TMC problem
    May 2009
    Newcastle-under-Lyme Staffordshire
    40 Post(s)
    Hi all,
    I have just taken delivery of an Audi A6 fitted with the new MMI 3G with MMI Navigation Plus (HDD based) and AMI. My car has an odd problem with radio reception, traffic bulletins and TMC which I'm guessing is a software issue. When I start the car and the MMI initialises, everything is OK - TMC enables and shows info messages, TP traffic bulletins interrupt normal radio/iPod playback, and all expected FM radio stations appear in the MMI display. If I drive the car any distance, however, things begin to go awry. If the radio is tuned to (say) Radio 1 on 97.9, it does not detect regional changes to the station's frequency, and eventually loses the signal as I move to a different area of the country. TP Traffic Bulletins also stop, and TMC disables itself. If I look at the list of other stations displayed, it still appears exactly as it did when the MMI initialised, so the car could by then be in Manchester but still show BBC Radio Oxford as being available. I have discovered that if I switch waveband to MW then back to FM again, everything rights itself - local radio stations appear, TMC re-enables, national stations (eg Radio 1) are back to normal reception, traffic bulletins start to come through again, and out-of-area stations disappear.
    I have taken the car to my local dealer, but they seem quite puzzled by the problem, and have ordered some new parts for the car (radio boosters and a new rear window). Given the nature of the problem and the initial excellent radio reception, I'm not convinced that this will make a difference. I'm just wondering if anyone else out there has an A6 with the same spec and is experiencing the same problems as me (and in a perfect world knows what the resolution is), or is it just a glitch with my car?
    Many thanks,
    MF.
    Edit. As of February 2010, Mark Chesworth identified a workaround whereby switching the Traffic Programme (TP) function to OFF in the radio setup allows the radio to self-tune as expected, and TMC to remain active. Obviously this is not a complete solution, as TP messages are often useful when not using the navigation system, but it is keeping me sane until Audi fix the software.
    MF.
    Edit 2. As of October 2010, Audi have released a Revision T software update CD which fixes the radio retuning/TMC/TP issues. Cars with this fix applied can now safely have the TP function enabled. The update also fixes the navigation voice prompt errors on cars with 3G navigation high and low ("now turn left" fix).
    MF.
    Last edited by MFGF; 18-10-2010 at 12:32 PM. Reason: Added info on new software revision now available.
  2. Re: A6 MMI 3G radio/TP/TMC problem
    Dec 2006
    Wiltshire
    It sounds like software to me - not hardware. I would get the dealer to check what the latest MMI software/firmware version is and make sure you have it installed.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  3. Re: A6 MMI 3G radio/TP/TMC problem
    May 2009
    40 Post(s)
    Thanks. I will get back to the dealers and ask them to check the software versions.
    MF.
  4. Re: A6 MMI 3G radio/TP/TMC problem
    Jul 2009
    stockton
    i have exactly the same problem in my new 2010 audi a4 with MMI 3G, did you get yours sorted out??
  5. Re: A6 MMI 3G radio/TP/TMC problem
    May 2007
    knee deep in clunge
    13 Post(s)
    please post your current mmi sw version
    Press the appropriate function selector button to activate the RADIO menu.
    First press SET UP and then RETURN and hold both buttons down simultaneously
    for approx. five seconds until the display changes.
  6. Re: A6 MMI 3G radio/TP/TMC problem
    Jul 2009
    stockton
    software version
    HNAV_EU_P0022_DI
    8R006884E_ECE5.8.5
    THIS IS THE ONLY INFORMATION I COULD FIND..
  7. Re: A6 MMI 3G radio/TP/TMC problem
    Jul 2009
    stockton
    Device: H.bn.eg
    s/w: 8t2035666d
    index: 0047
    date: 7.4.09
    device: Radio std
    s/w : 4f0035056b
    index 0020
    date: 19.02.09
    h/w: 4f0035056
    train version p0022
    mu version 0047
  8. Re: A6 MMI 3G radio/TP/TMC problem
    May 2007
    knee deep in clunge
    13 Post(s)
    Quote Originally Posted by markchesworth View Post
    software version
    HNAV_EU_P0022_DI
    8R006884E_ECE5.8.5
    Spot on,i will look into this and correct me if i am wrong is this nav plus option 3G
  9. Re: A6 MMI 3G radio/TP/TMC problem
    May 2009
    40 Post(s)
    Hi Mark.
    No - no resolution for my A6 yet. So far the dealer has replaced the aerial (ie the rear window), added radio boosters and replaced the radio unit. None of this made any difference. My car is back with them today, and they are keeping it overnight, but I don't think they know where to go from here.
    A8 Tech, the dealer has my car for the next two days, so I can't find the s/w version right now, but I will get it when my car is returned and post it here.
    MF.
  10. Re: A6 MMI 3G radio/TP/TMC problem
    May 2007
    knee deep in clunge
    13 Post(s)
    I have looked but suspect your 5f 3g unit is faulty or requires a reset of the adaption channels,there is only one 3g update at this time for nav plus only but early version 3g had a few issues but that was mainly blank screen or nav display showing incorrect vehicle position.The nav info is stored on the 3g hard drive and there are no current map updates which include tmc but i am sure your dealer has a report running with tech support on this and they will be doing there utmost to resolve the issue.
  1. A6 2.0 Diesel 2006 - idling problem
    By corcoran in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-12-2013, 02:02 PM
  2. Audi A6 Comfort Module Repair Petition
    By Arnot in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-03-2008, 01:50 PM
  3. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
  4. New Sporting Audi A6 S Line models arrive in britain
    Last Post: 15-07-2004, 09:40 PM
  5. New A6 to dominate Audi stand
    Last Post: 23-06-2004, 11:19 PM
